5.2. Building a Batch Solver
> build_mfixsolver --batch
> ls
build mfixsolver
This command will build an executable mfixsolver in the current directory.
The build directory can be deleted, and the custom mfixsolver will still run. However, leaving the build directory will greatly speed up rebuilds if you want to edit the UDFs and run build_mfixsolver again.
5.2.1. Configuration options
Arguments may be passed to build_mfixsolver to specify various options: compiler, compiler flags, SMP/DMP support, and other options. All configuration options can be displayed with:
> build_mfixsolver --help
                        [FC=<Fortran compiler>]
                        [FCFLAGS=<Fortran flags>]
Argument
FC=<compiler>
Specify the Fortran compiler command
FCFLAGS=<flags>
Specify Fortran compiler flags
--dmp
Enable distributed memory support (MPI)
--smp
Enable shared memory parallel support (OpenMP)
The Fortran compiler is specified by passing the FC argument to build_mfixsolver. If the FC argument is not specified, the script will search the environment for a Fortran compiler (usually gfortran).
Table 5.1 compiler value for FC
Compiler
gfortran
GNU Fortran compiler (serial/smp)
ifort
Intel Fortran compiler (serial/smp)
mpif90
Generic MPI Fortran wrapper (dmp/combined smp-dmp)
mpifort
mpiifort
Intel MPI Fortran wrapper (dmp/combined smp-dmp). Older versions commonly use the mpif90 command.
Compiler flags can be specified by passing the FCFLAGS argument to build_mfixsolver. If the FCFLAGS argument is not specified, the compiler defaults are used.
Table 5.2 Compiler Flags for gfortran and Intel Fortran
GNU Fortran
Intel Fortran
-g
-g
Produce debugging information
-O0, -O1, -O2, -O3,
-O0, -O1, -O2, -O3,
  • -O0 for debugging
  • -O2 for production
-fcheck=all
-check all
Generates runtime checks useful for debugging
-fbacktrace
-backtrace
Print a full stack trace when a runtime error occurs
-g
-g
Generates complete debugging information
-march=native -O3
Generates optimized code for the local machine’s CPU. May not run on different machines.
Running build_mfixsolver will display the flags specified with FCFLAGS, and other compiler flags that are always defined by the build scripts:
--    Build type        = RelWithDebInfo
--    Fortran compiler  = /usr/bin/gfortran
--    Fortran flags     = -Wall -cpp -ffree-line-length-0 -fconvert=big-endian -fPIC
The build_mfixsolver script will test specified Fortran compiler with any specified flags (covered next). If the compiler is not found or if the compiler doesn’t work with the specified flags, no Makefile will be generated and an error message will be printed. When posting a question on the forum about build issues, include any error messages.
5.2.2. Make options
build_mfixsolver will pass the options -j and -k on to make. Building with -j on multicore systems will speed up the build process.
> build_mfixsolver --batch -j
5.2.3. Building
To build the MFiX batch solver, run build_mfixsolver with the --batch option.
> ls
SP2D.mfx  usr0.f  usr1.f  usr_mod.f  usr_rates.f
...build output...
> ls  *
build mfixsolver SP2D.mfx  usr0.f  usr0.o usr1.f  usr1.o  usr_mod.f  usr_mod.o usr_rates.f usr_rates.o
Note the absence of a lib directory. The lib directory has the Python module for the interactive solver, and therefore is not present for a batch solver. Also, mfixsolver is a binary executable (not a wrapper script).
To build the MFiX batch solver, with optimized code generated for the curren CPU:
> build_mfixsolver --batch FCFLAGS="-march=native -O3"
