solver. It is also necessary to build a custom solver to use SMP or DMP
multprocessing. A custom solver is an mfixsolver executable built in the project directory, specific to that project.
Press the (Build) button to display the Build Dialog box. Select
default solver.
> ls
> build_mfixsolver
...build output...
> ls *
mfixsolver, that runs the case-specific MFiX solver (which is
installed in the lib directory).
build_mfixsolver again.
