User-Defined Functions¶
User-Defined Functions (UDFs) are source files in the same directory as the project file that define code that is called by specific locations in the main MFiX code. UDFs are used to customize the behavior of MFiX. One common usage is for creating user-specific output files. In many cases, creating a personalized UDF is preferable to using post_mfix.
Because MFiX is open source, users may modify any *.f or *.inc file
under the model directory.
the contents of the adiabaticFlame test case located in the legacy_tests
directory.
> cd tutorials/tfm/silane_pyrolysis_2d
> ls
The SP2D.mfx file is the project file, and the usr*.f files are the UDFs used by this project.
simulation. After running build_mfixsolver, a re-examination of the same folder reveals:
> build_mfixsolver
...long output...
> ls
Each UDF has a corresponding dependency (.d) file and object (.o) file.
If a project has a usr_rates.f UDF, an additional species.inc file is generated from
The .d and .o files are intermediate dependency and object files that are
File Name: |
Usage Description |
User-defined drag function |
Chemical reaction rates |
DES chemical reaction rates |
File Name: |
Usage Description |
File Name: |
Usage Description |
Subroutine called every DEM timestep after calculating DES source terms but before source terms are applied to the particles. |
Call Graph for UDF Subroutines¶
Call Graph for UDF DES Subroutines¶
Note that the USR_ keywords do not have any explicit behavior. They are only basic
specifying USR_X_w does not result in the associated I index, USR_I_W
specified.
