solver. It is also necessary to build a custom solver to use SMP or DMP
multprocessing. A custom solver is an mfixsolver
executable built in the project directory, specific to that project.
Press the (Build) button to display the Build Dialog box. Select
For example, the tfm/silane_pyrolysis_2d
default solver.
> ls
To build a custom solver for tfm/silane_pyrolysis_2d
> build_mfixsolver
...build output...
> ls *
The build_mfixsolver
command creates a wrapper script
mfixsolver
, that runs the case-specific MFiX solver (which is
installed in the lib
directory).
The build
will still run. However, leaving the build
directory will greatly
build_mfixsolver
again.
