3.6. Three-dimensional DEM hopper¶
5 cm diameter hopper |
10 x 25 x 10 |
0.003 m |
NA |
NA |
3.6.1. Create a new project¶
Solverdrop-down menuCheck the
Disable Fluid Solver (Pure Granular Flow)checkbox.
3.6.3. Enter the geometry¶
3.6.4. Enter the mesh¶
10for the x cell valueEnter
25for the y cell valueEnter
10for the z cell value
namesuch as “walls”Check the
Select facets (STL)checkbox to turn the region into a STL region. The facets of the hopper should now be selected.
the Y direction by:
Slice facets.Check the
Filter facets based on normalscheckboxEnter a vector pointed in the positive
3.6.6. Create a solid¶
On the Solids pane
In the DEM sub-pane, check Enable automatic particle generation checkbox
the hopper by:
Select regiondialog, select “No Slip Wall” from theBoundary typedrop-down menuSelect the “walls” region and click
3.6.9. Select output options¶
OutputpaneOn the
VTKsub-paneOn the “select region” dialog, select “particle data” from the
output typedrop-down menuSelect the “Background IC” region from the list to save particle data over the entire domain
DiameterandTranslational velocitycheckboxes
Change
Stop timeto2.0secondsChange
Time stepto1e-3secondsChange
3.6.11. Run the project¶
3.6.12. View results¶
