13. Frequently Asked Questions
13.1. How do I ask question, or send feedback?
  • Please allow sufficient time (2-3 business days) for MFiX developers and users to reply before posting unanswered questions again.
  • Before submitting help requests, please review prior postings to see if the question has already been answered. Use the search bar at the top of the forum page to search a specific topic.
  • Please include a complete description of the issue, including:
    • Type of issue: Setup in GUI, meshing, solver crash, solver non-convergence, etc.
    • Description: Details on how to reproduce the issue.
      • MFiX version.
      • Operating system.
      • Solver (default solver, parallel dmp solver etc.).
      • If MFiX crashed or failed, how long does it take?
      • Attempts to fix the issue: Include what you have tried, what helped and what didn’t help.
    • Attach all relevant files to reproduce the issue (*.mfx, *.stl, *.f, particle_input.dat etc.):
      • Create a zip file from main menu> submit bug report.
      • Upload this zip file to the post.
      • Verify anyone can reproduce the error with the information given and attached files.
  • Questions that have missing information will likely remain unanswered. Did you:
    • Select the relevant category (Installation / How to / Bug report / Share)?
    • Search the forum for similar issues, read the documentation (https://mfix.netl.doe.gov/doc/mfix/latest)?
    • Inspect the console, error and warning messages?
    • Modify the code, or write UDFs?
    • Run the solver in debug mode?
    • Provide sufficient information and attach relevant files?
13.2. Graphical User Interface (GUI)
13.2.1. How do I change the look & feel of the GUI?
13.2.2. MFiX (VTK) crashes on RHEL/CentOS 7 with the following error message:
If this solves the issue for your system, you can add export MESA_GL_VERSION_OVERRIDE=3.2 to your shell profile.
13.2.3. How do I build the custom solver in parallel?
Building the solver in parallel means using several cores to build the solver. It will significantly decrease the time to build the solver. This applies to all solvers (serial, smp and dmp), and it does not affect which solver is built, only how fast it is built. The custom solver can be built in parallel from the GUI by checking the “Build solver in parallel” check box. This will pass the -j option to the make command.
13.3. Pausing and restarting the solver
13.3.1. Play/Pause/Reinit
While the simulation is running, it can be paused by pressing the Pause (pause) button. Many settings can be modified, such as stop time, monitor and VTK settings, boundary conditions, etc. Settings that cannot be changed (such as initial conditions or grid spacing) will be disabled while the simulation is paused. To resume the simulation, save the new settings by pressing the Save (save) button and press the Start (start) button.
13.3.2. Restart a simulation from current time
Once a simulation has run to completion, it can be restarted from the current simulation time. Increase the stop time in the “Run” pane, press the Save (save) button, and press the Start (start) button. In the “Run solver” dialog box, check the “Restart” check box and select “Resume”. Then press the “Run” button.
13.3.3. Restart a simulation from the beginning
Once a simulation has run to completion, or if you pressed the Stop (stop) button, the simulation can be restarted from the beginning. This is typically needed if the simulation settings need to be changed and the current results are not needed anymore. First press the Reset (reset) button to delete the current results. Next change the simulation settings as needed (if any). Press the Save (save) button, and press the Start (start) button.
13.4. What system of units does MFiX use?
Property
MFiX SI unit
length, position
meter (m)
mass
kilogram (kg)
time
second (s)
thermal temperature
Kelvin (K)
energy†
Joule (J)
amount of substance‡
kilomole (kmol)
force
Newton (N=kg·m/s2)
pressure
Pascal (Pa=N/m2)
dynamic viscosity
Pa·s
kinematic viscosity
m2/s
gas constant
J/K·kmol
enthalpy
J
specific heat
J/kg·K
thermal conductivity
J/s·m·K
  • amount per time per volume for Eulerian model reactions kmol/m3.s
  • amount per time for Lagrangian model reactions kmol/s
13.5. What do I do if a run does not converge?
13.5.1. Initial non-convergence
Holding the time step constant (DT_FAC=1) and ignoring the stalling of iterations (DETECT_STALL=.FALSE.) may help in overcoming initial nonconvergence. Often a better initial condition will aid convergence. For example, using a hydrostatic rather than a uniform pressure distribution as the initial condition will aid convergence in fluidized bed simulations.
When using constant gas density, better convergence may be achieved by increasing the number of gas pressure iterations. Go to Numerics>Linear solver tab and set the number of gas pressure iterations (“Iter.” column) to say 50 instead of 20.
If there are computational regions where the solids tend to compact (i.e., solids volume fraction less than EP_star), convergence may be improved by reducing UR_FAC(2) below the default value of 0.5.
Convergence is often difficult with higher order discretization methods. First order upwinding may be used to overcome initial transients and then the higher order method may be turned on. Also, higher-order methods such as van Leer and minmod give faster convergence than methods such as superbee and ULTRA-QUICK.
13.5.2. Non-convergence due to bad cut-cell mesh
Small cell removal
Fig. 13.1 Removing small cut-cells
Errors related to singular matrix may be due to poor mesh quality as well. Warning messages such as:
WARNING leg_bicgs.f:269, Warning: Singular matrix detected when solving for: EPp
will likely lead to failure and are often caused by non water-tight geometry, inclomplete boundary condition specifications, STL files with collapsed edges. In these cases, it is recommended to first check the STL file and mesh quality (visualise the mesh and check the mesh statistics). Adjusting the meshing tolerances may help solve the issue.
13.6. Discrete Element Model (DEM)
13.6.1. How to provide initial particle positions in particle_input.dat file?
We can read the initial particle data from a text file, called particle_input.dat. The format of this file has changed in the 20.3 release. The old file version can still be used but it is recommended to use the latest format.
Below is an example of a particle_input.dat file (the line number is shown on the left and it not part of the data itself):
  • Line 1 : File version. Do not change this line.
  • Lines 2-18 : Instructions to use the file.
  • Line 19 : This is a 3D geometry. The first 3 columns in the data section will be x,y,z.
  • Line 20 : We will read data for 35361 particles.
  • Line 24 : We always read coordinates in the first 2 or 3 columns (do not change)
  • Line 25 : We do not read particle’s phase ID for each particle. It is assigned a constant value: 1
  • Line 26 : We will read the particle’s diameter in the next column (column#4).
  • Line 27 : We do not read particle’s density. It is assigned a constant value: 2500.0 kg/m^3
  • Line 25 : We do not read particle’s velocity. It is assigned a constant value: (u,v,w) = (0.0,0.0,0.0) m/s
  • Lines 29-30: This is a cold, non reacting case, we do not read Temperature or species.
  • Line 31 : We do not have user scalars, so we do not read them.
  • Lines 32-34: Data header
1 Version 2.0
3 Instructions:
19 Dimension:    3
20 Particles:    35361
22 Variable      Read(T/F)     Default value (when Read=F)
24 Coordinates:     T          Must always be T
25 Phase_ID:        F          1
26 Diameter:        T
27 Density:         F          2500.0
28 Velocity:        F          0.0 0.0 0.0
29 Temperature:     T          (Ignored if energy eq. is not solved)
30 Species:         T          (Ignored if species eq. are not solved)
31 User_Scalar:     T          (Ignored if no user scalars are defined)
33     X (m)           Y (m)           Z (m)       Diameter (m)
35 -5.07749E-02    -7.98147E-01    -2.00612E-01    9.71052E-03
36 -4.86164E-02    -8.16202E-01    -2.25035E-01    8.34185E-03
37 -3.16460E-02    -8.13702E-01    -2.19164E-01    1.09747E-02
38 -3.32833E-02    -8.25178E-01    -2.19393E-01    9.67983E-03
39 -2.48844E-02    -8.30159E-01    -2.16423E-01    9.84182E-03
40 -8.57591E-03    -8.38121E-01    -2.08773E-01    9.92759E-03
41 -2.75312E-03    -8.32665E-01    -2.00770E-01    1.07560E-02
42 1.57276E-02     -8.37839E-01    -2.08196E-01    1.04387E-02
43 1.96605E-02     -8.31447E-01    -2.15105E-01    9.97808E-03
44 2.71083E-02     -8.26450E-01    -2.19492E-01    9.99619E-03
45 3.55440E-02     -8.28885E-01    -2.15687E-01    9.15771E-03
46 4.45244E-02     -8.28239E-01    -2.11771E-01    1.05089E-02
47 4.70488E-02     -8.22092E-01    -2.19129E-01    9.33350E-03
The particle_input.dat file can be edited in any text editor, including the GUI editor, and be saved in the project directory. Please run the 2D DEM fluid bed with central jet tutorial from the GUI, or see the DEM initial conditions last section for an example.
0.2000D-03  0.2000D-03  0.5000D-04  0.1800D+04  0.0000D+00  0.0000D+00
0.6000D-03  0.2000D-03  0.5000D-04  0.1800D+04  0.0000D+00  0.0000D+00
0.1000D-02  0.2000D-03  0.5000D-04  0.1800D+04  0.0000D+00  0.0000D+00
0.1400D-02  0.2000D-03  0.5000D-04  0.1800D+04  0.0000D+00  0.0000D+00
0.2000D-03  0.2000D-03  0.1000D-01  0.5000D-04  0.1800D+04  0.0000D+00  0.0000D+00  0.0000D+00
0.6000D-03  0.2000D-03  0.1000D-01  0.5000D-04  0.1800D+04  0.0000D+00  0.0000D+00  0.0000D+00
0.1000D-02  0.2000D-03  0.1000D-01  0.5000D-04  0.1800D+04  0.0000D+00  0.0000D+00  0.0000D+00
0.1400D-02  0.2000D-03  0.1000D-01  0.5000D-04  0.1800D+04  0.0000D+00  0.0000D+00  0.0000D+00
13.6.2. How to avoid particles going through solid walls in DEM simulations?
Particles going through wall
Fig. 13.2 Left: Soft particles (kn=kn_w=100 N/m) going through the cyclone wall. Right: Harder particles (kn=kn_w=1000 N/m) bouncing off the wall.
kn settings
Fig. 13.3 Spring stiffness settings in the GUI
  • Missing facets from the STL files: If the STL file is not waterproof, particles can go through the holes. The STL file must be inspected and corrected to fix this issue. The STL file should also not have facets with an angle smaller than the facet angle tolerance (Mesh> mesher pane).
  • DEM solids time step is too large. If the DEM solids time step is too large, collisions may be missed and particles can go through the wall. Increasing the spring stiffness will automatically reduce the solids time step, but it may be necessary to increase the DEM time step factor (Solids>DEM pane). It is recommended to not lower the DEM time step factor below the default value of 50.
13.7. SuperQuadric Particle Model (SQP)
13.7.1. How to specify the particle shape?
The shape of non-spherical particles is defined with five parameters, a,b,c,m,n. The surface of the particle is defined with the following superquadric equation:
[(xa)m+(yb)m]nm+(zc)n1=0
The exponents m and n in the superquadric equation above correspond to ϵ1=2n and ϵ2=2m in references [1-3]. The notation used in MFiX is consistent with [4].
Fig. 13.4 Superquadric designer
superquadric exponent map (favorable values of m and n)
Fig. 13.5 Favorable exponent map
Examples:
a
b
c
m
n
shape
view
0.003
0.003
0.003
2.0
2.0
sphere
sphere
0.003
0.001
0.006
2.0
2.0
ellipsoid
ellipsoid
0.003
0.001
0.006
8.0
8.0
cuboid
cuboid
0.003
0.003
0.006
2.0
8.0
cylinder
cylinder
13.8. Meshing
13.8.1. How to verify/flip STL file facet normals?
STL normals, Internal flow
Fig. 13.6 Displaying STL normals, internal flow
STL normals, External flow
Fig. 13.7 Flipping STL normals to model an external flow
13.8.2. How to manually specify a grid partition for DMP runs?
2        4          2    ! NODESI, NODESJ, NODESK
0        10
1        10
0        10
1        10
2        10
3        70
0        10
1        10
0        10
1        10
0        10
1        10
2        10
3        70
0        10
1        10
Small cell removal
Fig. 13.8 Default partition (uniform distribution)
Small cell removal
Fig. 13.9 Adjusted partition in vertical direction (specified with gridmap.dat)
13.9. Particle in Cell (PIC)
13.9.1. How To Choose a Good Statistical Weight for PIC Runs?
  1. Collect the following information:
    1. Diameter of an equivalent single spherical particle (m)
    2. Mass density of particles (kg/m 3 )
    3. Max-pack solids fraction of particles for simulation
  2. Choose a mesh for the simulation. Separately, calculate an average cell volume (m 3 ) and a minimum cell volume (m 3 ).
  3. Using max-pack solids fraction (which must be defined for PIC, 1-EP_STAR), calculate an average cellular volume available for solid (m 3) and a minimum cellular volume available for solid (m 3).
  4. Using particle diameter, calculate the number of spherical particles these average cellular volumes available for solid represent. Assuming a uniform mesh, this calculated number, as a rounded-down integer, would represent the maximum statistical weight one can choose in a PIC simulation, although it is highly unlikely one would choose this value. In a variable mesh, the value associated with the minimum cell volume is the maximum statistical weight. (Note: using an average cellular volume for this calculation allows a balance of parcel load in both large and small cells.) Note that a user does not need to know the solids fraction distribution that they expect in a simulation, only the max-pack solids fraction, which is a constant.
  5. Now the balancing act between parcel count, actual solids fraction and mass error begins. First, choose a statistical weight value. An easy way to make a first approximation is to use the maximum statistical weight from (4) and divide by an integer which in your mind represents the number of parcels you want per cell. Statistical weights derived like this will naturally give a solids fraction very close to whatever the original desired value from (1) was, and minimize mass error in a simulation. The statistical weight does not need to be an integer, because partial particles make sense in PIC. While the parcel count in an individual cell will initially begin as an integer, there is no limitation that says an integer number of particles must make up a parcel. Choosing an integer value for statistical weight does make it simple to imagine the parcels as grouped entities of particles, but it may interfere with expectations for representative solids volume fraction per cell. Note, however, that regardless of what the user specifies as a statistical weight, the MFIX program will collect truncated mass values in each cell until enough mass to represent a full parcel accumulates, whereupon a single extra parcel will be placed in the domain.
  6. It is advisable to inspect your fully populated PIC parcel domain to make sure you have not applied a value that does not make visual or physical sense. This is particularly true for very dilute flow and highly packed flow. For dilute flows, choosing a statistical weight that is too large will result in a simulation that cannot possibly capture expected flow dynamics. In a highly packed flow, choosing a statistical weight that is too low may result in non-physical packing, and an overly large local solids fraction. As such, be certain to note the values reported in the MFIX output for desired solids fraction and calculated solids fraction, then assure yourself that the numbers are within some reasonable error band.
13.9.2. PIC statistical weight example
  • 0.1 kg of 0.001 m particles with density 1000 kg/m 3
  • in a volume that is 0.1 x 0.1 x 0.1 m 3 defined by a 10 x 10 x 10 mesh
  • with max-pack of 0.4 (theoretical limit of random packing of spheres is 0.36)
First, calculate the volume of 1 particle: V_particle= π/6 (0.001)3 = 5.236E-10 m 3
13.9.3. Meshing Basics for PIC Runs
13.9.4. Choosing Primary PIC Parameters
PIC parcels do not behave like DEM particles. There are no Newtonian physical laws that govern collisions. Instead, PIC utilizes a solids stress ( τp) field that influences solids motion through a coupling with the momentum equation. Specifically, the solids stress is calculated as:
τp=Ppϵpγmax[ϵcpϵp,δ(1ϵp)]
In MFIX, the parameters that the user can control to define this solids stress are an empirical pressure constant (PSFAC_FRIC_PIC ( Pp ), a volume fraction exponential scale factor (FRIC_EXP_PIC ( γ), void fraction at maximal close packing(EP_STAR ( ϵcp) and a non-singularity constant (FRIC_NON_SING_FAC ( δ). The only other variable at play within the solids stress model is solids void fraction ( ϵp ) which is calculated dynamically as the simulation progresses.
The parameters used in PIC are very robust. The default values of Pp =100, γ =3, δ =1.0E-7 should work well for most systems. There should be no reason to change δ. The value for ϵcp will vary depending on your application, although it is worth noting that there is a theoretical limit of ~0.36 for the random packing of equal spheres. It is important to note that ϵcp represents the void or gas fraction per cell, and not the solids fraction. The effects of changing the values of Pp and γ are very problem specific. For example, sedimentation cases (on which the solids model was originally built) will model best with Pp =1, γ =2 so that gravity has the most effect on the system through the momentum equation. But, very dynamic cases (U_mf>10) where we expect the solids to more greatly affect the hydrodynamics of the system may respond better with selections like Pp =1000, γ =3. Essentially, like all CFD models, it may be necessary to tune the PIC model to your specific case. As a rule of thumb, larger Pp at constant γ will result in particles that move more dynamically (as the selection will linearly increase the solids stress). But, larger γ at constant Pp will reduce the solids stress exponentially and dampen overall solids motion. The largest values of solid stress will occur when Pp is large and γ is small.
13.9.5. Choosing Secondary PIC parameters
13.9.6. Why can’t I define parcels per cell instead of particles per parcel?
  1. The user has full control over the statistical weights of the PIC parcels and is not reliant on the computer code to calculate those values without knowledge of the simulation being run.
  2. In most CFD simulations, mesh can be highly variable. When a user defines parcels/cell, the smallest cell will limit the number of parcels that can be placed in any cell at initialization. By defining particles/parcel, the check we suggest for examining the smallest cell only limits the overall size of the parcel, and a more even solids void fraction can be achieved at start-up. An argument can be made that multiple initialization regions can be created to smooth solids void fraction using the parcel/cell method, but this only complicates set-up.
13.9.7. What is a good number (or range) for the number of parcels per cells?
13.9.8. What solids model parameter values work best for the PIC model when running 2 densities that are roughly 10x different in magnitude?
A density difference like this (say 300 kg/m 3 and 3,000 kg/m 3) will cause natural physical separation in most systems. To capture the best physics in a PIC model where density drives strong gravitational effects, choose Pp =1 and γ =5 to begin. You may still need to adjust these parameters but these choices will give you a good place to start.
