13. Frequently Asked Questions¶
13.1. How do I ask question, or send feedback?¶
Please allow sufficient time (2-3 business days) for MFiX developers and users to reply before posting unanswered questions again.
MFiX version.
Operating system.
*.mfx,*.stl,*.f,particle_input.datetc.):Create a zip file from main menu> submit bug report.
Run the solver in debug mode?
13.2. Graphical User Interface (GUI)¶
13.2.1. How do I change the look & feel of the GUI?¶
13.2.2. MFiX (VTK) crashes on RHEL/CentOS 7 with the following error message:¶
If this solves the issue for your system, you can add export
MESA_GL_VERSION_OVERRIDE=3.2 to your shell profile.
13.2.3. How do I build the custom solver in parallel?¶
parallel” check box. This will pass the -j option to the make command.
13.3. Pausing and restarting the solver¶
13.3.1. Play/Pause/Reinit¶
(save) button
and press the
(start) button.
13.3.2. Restart a simulation from current time¶
and press the
13.3.3. Restart a simulation from the beginning¶
First press the
(save) button, and press the
(start) button.
13.4. What system of units does MFiX use?¶
MFiX SI unit |
length, position |
meter \((m)\) |
mass |
kilogram \((kg)\) |
time |
second \((s)\) |
thermal temperature |
Kelvin \((K)\) |
energy† |
Joule \((J)\) |
amount of substance‡ |
kilomole \((kmol)\) |
force |
Newton (\(N = kg·m/s^2\)) |
Pascal (\(Pa = N/m^2\)) |
dynamic viscosity |
\(Pa·s\) |
kinematic viscosity |
\(m^2/s\) |
gas constant |
\(J/K·kmol\) |
enthalpy |
\(J\) |
specific heat |
\(J/kg·K\) |
thermal conductivity |
\(J/s·m·K\) |
amount per time per volume for Eulerian model reactions \(kmol/m^3.s\)
amount per time for Lagrangian model reactions \(kmol/s\)
13.5. What do I do if a run does not converge?¶
13.5.1. Initial non-convergence¶
Holding the time step constant (DT_FAC=1) and ignoring the stalling of
iterations (DETECT_STALL=.FALSE.) may help in overcoming initial nonconvergence.
When using constant gas density, better convergence may be achieved by increasing the number of gas pressure iterations. Go to Numerics>Linear solver tab and set the number of gas pressure iterations (“Iter.” column) to say 50 instead of 20.
reducing UR_FAC(2) below the default value of 0.5.
Convergence is often difficult with higher order discretization methods. First order upwinding may be used to overcome initial transients and then the higher order method may be turned on. Also, higher-order methods such as van Leer and minmod give faster convergence than methods such as superbee and ULTRA-QUICK.
13.5.2. Non-convergence due to bad cut-cell mesh¶
Fig. 13.1 Removing small cut-cells¶
Errors related to singular matrix may be due to poor mesh quality as well. Warning messages such as:
WARNING leg_bicgs.f:269, Warning: Singular matrix detected when solving for: EPp
will likely lead to failure and are often caused by non water-tight geometry, inclomplete boundary condition specifications, STL files with collapsed edges. In these cases, it is recommended to first check the STL file and mesh quality (visualise the mesh and check the mesh statistics). Adjusting the meshing tolerances may help solve the issue.
13.6. Discrete Element Model (DEM)¶
13.6.1. How to provide initial particle positions in particle_input.dat file?¶
not part of the data itself):
Lines 32-34: Data header
1 Version 2.0
3 Instructions:
19 Dimension: 3
20 Particles: 35361
25 Phase_ID: F 1
26 Diameter: T
27 Density: F 2500.0
28 Velocity: F 0.0 0.0 0.0
The particle_input.dat file can be edited in any text editor, including the GUI editor, and be
13.6.2. How to avoid particles going through solid walls in DEM simulations?¶
Fig. 13.2 Left: Soft particles (kn=kn_w=100 N/m) going through the cyclone wall. Right: Harder particles (kn=kn_w=1000 N/m) bouncing off the wall.¶
Fig. 13.3 Spring stiffness settings in the GUI¶
13.7. SuperQuadric Particle Model (SQP)¶
13.7.1. How to specify the particle shape?¶
Fig. 13.4 Superquadric designer¶
Fig. 13.5 Favorable exponent map¶
Examples:
a |
b |
c |
m |
n |
shape |
view |
0.003 |
0.003 |
0.003 |
2.0 |
2.0 |
sphere |
0.003 |
0.001 |
0.006 |
2.0 |
2.0 |
ellipsoid |
0.003 |
0.001 |
0.006 |
8.0 |
8.0 |
cuboid |
0.003 |
0.003 |
0.006 |
2.0 |
8.0 |
cylinder |
13.7.2. Recommended settings¶
13.8. Meshing¶
13.8.1. How to verify/flip STL file facet normals?¶
Fig. 13.6 Displaying STL normals, internal flow¶
Fig. 13.7 Flipping STL normals to model an external flow¶
13.8.2. How to manually specify a grid partition for DMP runs?¶
0 10
1 10
0 10
1 10
2 10
3 70
0 10
1 10
0 10
1 10
0 10
1 10
2 10
3 70
0 10
1 10
Fig. 13.8 Default partition (uniform distribution)¶
Fig. 13.9 Adjusted partition in vertical direction (specified with gridmap.dat)¶
13.9. Particle in Cell (PIC)¶
13.9.1. How To Choose a Good Statistical Weight for PIC Runs?¶
13.9.2. PIC statistical weight example¶
13.9.3. Meshing Basics for PIC Runs¶
13.9.4. Choosing Primary PIC Parameters¶
13.9.5. Choosing Secondary PIC parameters¶
13.9.6. Why can’t I define parcels per cell instead of particles per parcel?¶
13.9.7. What is a good number (or range) for the number of parcels per cells?¶
13.9.8. What solids model parameter values work best for the PIC model when running 2 densities that are roughly 10x different in magnitude?¶
