default solver.
bash$ cd tutorials/tfm/silane_pyrolysis_2d/
bash$ ls
bash$ build_mfixsolver
...build output...
bash$ ls *
mfixsolver, that runs the case-specific MFiX solver (which is
installed in the lib directory).
build_mfixsolver again.
