4.11. Monitors
Data (such as volume fraction, pressure, velocity, etc.) for a given Region selection is written to a CSV file while the solver is running.
../_images/monitors.png
Fig. 4.10 Monitor pane
4.11.1. Region selection
To define a monitor, there must be a region already defined in the Regions Pane. Click the Add button at the top, which will open a popup window for selecting the region. A Monitor region is a single point, plane, or volume. Multiple regions cannot be combined for a monitor, and STL regions cannot be used for monitors.
4.11.2. Monitor Output
Filename
The monitor output file will have a default name based on the name of the monitor’s region. You can edit the filename of a monitor by selecting the monitor from the list of monitors and changing “Filename base”. The monitor data will be output to the Filename base with the extension .csv.
The monitor output file is in Comma Separated Value (CSV) format. The first line of the file provides header information. For example, running the Silane Pyrolysis tutorial (SP2D) will generate a file PROBE_SPECIES.csv:
# Run type: NEW
# "Time","x_g(1)","x_g(2)","x_g(3)","x_g(4)","x_g(5)","x_s(1,1)","x_s(1,2)"
    0.0000000    ,    0.0000000    ,    0.0000000    ,    0.0000000    ,    0.0000000    ,    1.0000000    ,    0.0000000    ,    1.0000000
Write Interval
4.11.3. Eulerian Monitors
  • Volume fraction (of all fluid species)
  • Fluid Pressure
  • Fluid Velocity
  • Fluid Temperature
  • Turbulent Kinetic Energy
  • Turbulent Dissipation
  • Volume fraction of each individual fluid species
  • Velocity of this solid phase
  • Bulk Density of this solid phase
  • Temperature of this solid phase
  • Granular Temperature of this solid phase
  • Pressure (total for all solid species for this solid phase)
  • Mass fraction of each individual species of this solid phase
Symbol
ϕijk
Variable value at indexed cell
εijk
Phase volume fraction at indexed cell
ρjk
Phase density at indexed cell
vjk
Phase velocity at indexed cell
Aijk
Cross-sectional area of cell
Vijk
Volume of indexed cell
4.11.3.1. Point Region
Value
ϕijk
4.11.3.2. Area or Volume Region
Sum
ijkϕijk
Min
minijkϕijk
Max
maxijkϕijk
Average
Average value of the field quantity in the selected region where N is the total number of observations (cells) in the selected region.
ϕ0=ijkϕijkN
Standard Deviation
The standard deviation of the field quantity in the selected region where ϕ0 is the average of the variable in the selected region.
σϕ=ijk(ϕijkϕ0)2N
4.11.3.3. Surface Integrals
Area
dA=ijk|Aijk|
Area-Weighted Average
ϕdAA=ijkϕijk|Aijk|ijk|Aijk|
Flow Rate
The flow rate of a field variable through a surface is computed by summing the product of the phase volume fraction, density, the selected field variable, phase velocity normal to the facet vn, and the facet area.
ερϕvndA=ijkεijkρijkϕijkvn,ijk|Aijk|
Mass Flow Rate
The mass flow rate through a surface is computed by summing the product of the phase volume fraction, density, phase velocity normal to the facet vn, and the facet area.
ερvndA=ijkεijkρijkvn,ijk|Aijk|
Mass-Weighted Average
ερϕ|vndA|ερ|vndA|=ijkεijkρijkϕijk|vn,ijkAijk|ijkεijkρijk|vn,ijkAijk|
Volume Flow Rate
The volume flow rate through a surface is computed by summing the product of the phase volume fraction, phase velocity normal to the facet vn, and the facet area.
εvndA=ijkεijkvn,ijk|Aijk|
4.11.3.4. Volume Integrals
Volume
dV=ijk|Vijk|
Volume Integral
ϕdV=ijkϕijk|Vijk|
Volume-Weighted Average
ϕdVV=ijkϕijk|Vijk|ijk|Vijk|
Mass-Weighted Integral
ερϕdV=ijkεijkρijkϕijk|Vijk|
ϕρεdVρεdV=ijkεijkρijkϕijk|Vijk|ijkεijkρijk|Vijk|
4.11.4. Lagrangian Monitors
  • Radius
  • Mass
  • Volume
  • Density
  • Translational velocity components
  • Rotational velocity components (DEM only)
  • Temperature
  • DES user variable (DES_USR_VAR)
Symbol
ϕp
Variable value of the indexed particle
mp
Mass of the indexed particle
Vp
Volume of the indexed particle
wp
Statistical weight of the indexed particle [1]
4.11.4.1. General particle properties
Sum
The sum of particle property, ϕp in the selected region is calculated using the following expression.
pwpϕp
Min
The minimum value of particle property phip is the selected region is obtained using the following expression.
minpϕp
Max
The maximum value of particle property phip is the selected region is obtained using the following expression.
maxpϕp
4.11.4.2. Averaged particle properties
Average
The average value of particle property, ϕp in the selected region is calculated using the following expression. For DEM simulations, the statistical weight of a particle, wp, is one such that the sum of the weights is the total number of observations in the selected region.
ϕ¯=pwpϕppwp
Standard Deviation
The standard deviation of particle property, phip in the selected region is calculated using the following expression. ϕ¯ is the averaged variable in the selected region.
σϕ=pwp(ϕpϕ¯)2pwp
Mass-weighted average
Mass-weighted average value of particle property, ϕp in the selected region is calculated using the following expression.
ϕ¯m=pwpmpϕppwpmp
Volume-weighted average
Volume-weighted average value of particle property, ϕp in the selected region is calculated using the following expression.
ϕ¯v=pwpVpϕppwpVp
4.11.4.3. Flow rates
Flow rate monitors for Lagrangian particles (DEM/PIC) are only valid for area (plane) regions. The set of particles crossing the flow plane, Γ is approximated using the height of the plane, h, the position of the particle, xp, and the particle velocity normal to the plane, vp such that
(vp)(xphΔt)>0
and
|vp||xphΔt|
Flow rate
The net flow rate of a general particle property ϕp is computed by summing the properties of the set of particles projected to have crossed the flow plane, Γ.
pΓwpϕpvp|vp|
Mass-weighted flow rate
The net mass-weighted flow rate is the sum of the general particle property ϕp multiplied by the particle mass, mp of the set of particles projected to have crossed the flow plane, Γ.
pΓwpmpϕpvp|vp|
Volume-weighted flow rate
The net volume-weighted flow rate is the sum of the general particle property ϕp multiplied by the particle volume, Vp of the set of particles projected to have crossed the flow plane, Γ.
pΓϕpwpVpvp|vp|
