solver. A custom solver is an mfixsolver
executable built in the project
5.1.2. Custom solver from command line¶
For example, the tfm/silane_pyrolysis_2d
default solver.
$ ls
To build a custom solver for tfm/silane_pyrolysis_2d
$ build_mfixsolver
...build output...
$ ls
build/ lib/ mfixsolver mfixsolver.so SP2D.mfx usr0.f usr0.o usr1.f usr_mod.f usr_rates.f
The build_mfixsolver
command creates a wrapper script
mfixsolver
, that runs the case-specific MFiX solver (mfixsolver.so
The build
will still run. However, leaving the build
directory will greatly
build_mfixsolver
again.
