5.1. Building custom interactive solver¶
solver. A custom solver is an mfixsolver
executable built in the project
5.1.1. Custom solver from GUI¶
compilation options. The “Build command” of the build dialog will show the
equivalent command for Building custom interactive solver.
5.1.2. Custom solver from command line¶
For example, the tfm/silane_pyrolysis_2d
default solver.
$ ls
To build a custom solver for tfm/silane_pyrolysis_2d
$ build_mfixsolver
...build output...
$ ls
build/ lib/ mfixsolver mfixsolver.so SP2D.mfx usr0.f usr0.o usr1.f usr_mod.f usr_rates.f
The build_mfixsolver
command creates a wrapper script
mfixsolver
, that runs the case-specific MFiX solver (mfixsolver.so
The build
will still run. However, leaving the build
directory will greatly
build_mfixsolver
again.
