5.1. Building custom interactive solver¶
5.1.1. Custom solver from GUI¶
compilation options. The “Build command” of the build dialog will show the
equivalent command for Building custom interactive solver.
5.1.2. Custom solver from command line¶
default solver.
$ ls
$ build_mfixsolver
...build output...
$ ls
build/ lib/ mfixsolver mfixsolver.so SP2D.mfx usr0.f usr0.o usr1.f usr_mod.f usr_rates.f
mfixsolver, that runs the case-specific MFiX solver (mfixsolver.so).
build_mfixsolver again.
