Please see the attached file, it contains the output information.
output.txt (18.6 KB)
Something is not right here. In output.txt I see
gfortran 12.2.0 h8acd90e_12 conda-forge
gfortran_impl_linux-64 12.2.0 h55be85b_19 conda-forge
the 12.2.0 version. I can’t understand why Without_module-load-mpi.txt says
-- The Fortran compiler identification is GNU 4.8.5
I think you may have accidentally loaded some module which is overriding the conda-forge installed compiler.
Make sure this environment is activated and no other GCC modules are loaded.
