Having trouble with starting mfix exa
Can you give me the reference that the above table of reactions came out of? And do you have the geometry of the furnace? The stl geometry should still be considered experimental.
Paper below is the reference for my reactions. The units are quite confusing for me to use them on MFIX-Exa.
Yang 등 - 2022 - CFD modeling of biomass combustion and gasificatio.pdf (2.9 MB)
Reference_test.zip contains the stl geometry and input file for reproducing and verifying the interpretation of the reference.
Furnace_test.zip contains the geometry of an actual biomass furnace and the corresponding input file.
Furnace_test.zip (158.8 KB)
Reference_test.zip (4.8 KB)
Thank you for your continued interest and support.
heterogeneous_reference.pdf (2.4 MB)
And here is another reference that corresponds to the reactions shown in the above figure.
Thank you.
time is a flat circle. not long after telling you I was going to start digging into your biomass gasification I had to drop it. it’s come back around internally and I’m interested in looking at this scheme you were planning to use from Yan et al (2016). Are you still interested in this @JunsungYeo?
