@cgw HI Charles,
YOU are right. I am trying to implement the NSW for the fluid phase and JJ BC for the solid phase. I used the Mixed wall type in GUI as you mentioned. However, the *.mfix file is like the 2nd format. According to the:
, it should be correct, but I think the BC does not implement correctly. What do you think?
Also, when we use the JJ BC for the solid phase, and the energy equation is not solved, the following terms should not be used in the solution:
bc_c_t_g(3) = 0.0 <
bc_c_t_s(3,1) = 0.0 <
bc_hw_t_g(3) = 0.0 <
bc_hw_t_s(3,1) = 0.0 <
bc_thetaw_m(3,1) = 0.0 <
> bc_c_theta_m(3,1) = 0.0
> bc_hw_s(3,1) = 0.0
6.mfx (18.9 KB)
Thanks,
Mohsen
