Well, turbulence can be notoriously difficult to define on BC and initialize, this is not unique to MFiX. If you want to evaluate this properly you should start with a simple 2D model and get your BC’s correct there first. So do not jump straight to an STL setup, which is prone to a wider array of errors, and not just turbulence related - that would probably make your life easier.
