Thank you very much for your help, which has solved a lot of problems that have been bothering me for a long time. If you encounter the problem of particle blockage, should you adjust the particle diameter or the particle speed? Both of these methods seem to pause my project and need to start from scratch. Is there any way to solve the particle blockage problem without losing the currently running project process?
