Finally problem solved. Thanks for kind guidance.
I find new thing.
There was issue with solver.
If I run the case with default\mfixsolver.exe, then it runs smoothly but required high time.
If I run the case with build\mfixsolver.bat, then it generated ‘‘overlap is too large’’ and solver terminated.
I build the solver as described in the post Enable parallell in windows - #9 by tyurata
