Particles in ghost cells
Thanks, Jeff. You mean I could find the information of STL file in run.log. I usually use this command for a DMP running: mpirun -np 4 ./mfixsolver > run.log &. So I can get the output file run.log. I will check it carefully. Thank you for your help again.
