Changes
Page history
Update Building MFIX with CSG EB on Spock
authored
Oct 28, 2021
by
Mark Meredith
Hide whitespace changes
Inline
Side-by-side
Building-MFIX-with-CSG-EB-on-Spock.md
View page @
3891cf6f
Spock compiler may required building MFIX and CSG-EB Conan package with different compilers.
# Background
# Check conan packages [optional]
The Cray compiler on Spock is based on Clang and uses the
`hipcc`
compiler wrapper.
# Problem
Building MFIX on Spock with the Cray compiler and CSG-EB support enabled has problems, because:
Building with the compiler
`CXX=hipcc`
fails to build.
`CXX=$ROCM_PATH/llvm/bin/clang`
builds successfully, but the resulting executable crashes.
# Procedure
The following steps are intended to work around these difficulties.
## Check conan packages [optional]
You can check which Conan packages are installed with the command, which looks something like:
@@ -29,13 +43,13 @@ zlib/1.2.11
first to see which conan packages are already built (and cached) on your system
# Build Conan CSG-EB package
cd subprojects/csg-eb
env CC=$ROCM_PATH/llvm/bin/clang CXX=$ROCM_PATH/llvm/bin/clang++ conan create .
@@ -63,7 +77,7 @@ zlib/1.2.11
# Build MFIX
# Build MFIX
❯ mkdir builddir; cd builddir
