Update Building MFIX with CSG EB on Spock authored by Mark Meredith's avatar Mark Meredith
...@@ -16,7 +16,7 @@ The following steps are intended to work around these difficulties. ...@@ -16,7 +16,7 @@ The following steps are intended to work around these difficulties.
## Check conan packages [optional] ## Check conan packages [optional]
You can check which Conan packages are installed with the command, which looks something like: Running `conan search` shows what Conan packages are present on your system; should look something like:
❯ conan search ❯ conan search
...@@ -51,7 +51,7 @@ env CC=$ROCM_PATH/llvm/bin/clang CXX=$ROCM_PATH/llvm/bin/clang++ conan create . ...@@ -51,7 +51,7 @@ env CC=$ROCM_PATH/llvm/bin/clang CXX=$ROCM_PATH/llvm/bin/clang++ conan create .
You can check which Conan packages are installed with the command, which looks something like: Running `conan search` again should now show a cached `csg-eb` package:
...@@ -88,7 +88,7 @@ cmake ~/mfix/exa/ -DMFIX_MPI=YES -DMFIX_OMP=NO \ ...@@ -88,7 +88,7 @@ cmake ~/mfix/exa/ -DMFIX_MPI=YES -DMFIX_OMP=NO \
-DAMReX_TINY_PROFILE=YES \ -DAMReX_TINY_PROFILE=YES \
-DMFIX_GPU_BACKEND=HIP -DAMReX_AMD_ARCH=gfx908 \ -DMFIX_GPU_BACKEND=HIP -DAMReX_AMD_ARCH=gfx908 \
-DCMAKE_CXX_FLAGS='-std=c++17' \ -DCMAKE_CXX_FLAGS='-std=c++17' \
-DMPI_COMPILER_FLAGS="--cray-print-opts=all" \ -DMPI_COMPILER_FLAGS="--cray-print-opts=all"
❯ cmake --build . ❯ cmake --build .
