Changes
Page history
Update Building MFIX with CSG EB on Spock
authored
Oct 28, 2021
by
Mark Meredith
Hide whitespace changes
Inline
Side-by-side
Building-MFIX-with-CSG-EB-on-Spock.md
View page @
ef813498
@@ -16,7 +16,7 @@ The following steps are intended to work around these difficulties.
## Check conan packages [optional]
You can check which Conan packages are installed with the command, which
look
s
something like:
Running
`conan search`
shows what Conan packages are present on your system; should
look something like:
❯ conan search
❯ conan search
@@ -51,7 +51,7 @@ env CC=$ROCM_PATH/llvm/bin/clang CXX=$ROCM_PATH/llvm/bin/clang++ conan create .
You can check which Conan packages are installed with the command, which looks something lik
e:
Running
`conan search`
again should now show a cached
`csg-eb`
packag
e:
❯ conan search
❯ conan search
@@ -88,7 +88,7 @@ cmake ~/mfix/exa/ -DMFIX_MPI=YES -DMFIX_OMP=NO \
-DAMReX_TINY_PROFILE=YES \
-DMFIX_GPU_BACKEND=HIP -DAMReX_AMD_ARCH=gfx908 \
-DCMAKE_CXX_FLAGS='-std=c++17' \
-DMPI_COMPILER_FLAGS="--cray-print-opts=all"
❯ cmake --build .
❯ cmake --build .
