Testing experiments
Testing experiments with RSpec
In the course of working with experiments, you might want to use the RSpec tooling that's built in. This happens automatically for files in spec/experiments, but for other files and specs you want to include it in, you can specify the :experiment type:
it "tests experiments nicely", :experiment do
end
Stub helper
You can stub experiments using stub_experiments, which is available without the :experiment type. Pass it a hash using experiment names as the keys, and the variants you want each to resolve to, as the values:
# Ensures the experiments named `:example` & `:example2` are both "enabled" and
# that each will resolve to the given variant (`:my_variant` and `:control`).
stub_experiments(example: :my_variant, example2: :control)
experiment(:example) do |e|
  e.enabled? # => true
  e.assigned.name # => 'my_variant'
end
experiment(:example2) do |e|
  e.assigned.name # => 'control'
end
Test control and candidate variants
For an experiment class that defines only control and candidate behaviors, use the defines control and candidate variants shared example:
RSpec.describe ExampleExperiment do
  it_behaves_like 'defines control and candidate variants'
end
The shared example checks that:
  • context_keys returns symbols.
  • The control and candidate behaviors return nil and run without errors.
The ExperimentsTestCoverage RuboCop cop accepts the shared example as test coverage for the experiment class. For other variants, or behaviors that return a value, write your own examples with the behavior matchers.
Exclusion, segmentation, and behavior matchers
You can also test things like the registered behaviors, the exclusions, and segmentations using the matchers.
class ExampleExperiment < ApplicationExperiment
  control { }
  candidate { '_candidate_' }
  exclude { context.actor.first_name == 'Richard' }
  segment(variant: :candidate) { context.actor.username == 'jejacks0n' }
end
excluded = double(username: 'rdiggitty', first_name: 'Richard')
segmented = double(username: 'jejacks0n', first_name: 'Jeremy')
# register_behavior matcher
expect(experiment(:example)).to register_behavior(:control)
expect(experiment(:example)).to register_behavior(:candidate).with('_candidate_')
# exclude matcher
expect(experiment(:example)).to exclude(actor: excluded)
expect(experiment(:example)).not_to exclude(actor: segmented)
# segment matcher
expect(experiment(:example)).to segment(actor: segmented).into(:candidate)
expect(experiment(:example)).not_to segment(actor: excluded)
Tracking matcher
Tracking events is a major aspect of experimentation. We try to provide a flexible way to ensure your tracking calls are covered.
You can do this on the instance level or at an "any instance" level:
subject = experiment(:example)
expect(subject).to track(:my_event)
subject.track(:my_event)
You can use the on_next_instance chain method to specify that it happens on the next instance of the experiment. This helps you if you're calling experiment(:example).track downstream:
expect(experiment(:example)).to track(:my_event).on_next_instance
experiment(:example).track(:my_event)
A full example of the methods you can chain onto the track matcher:
expect(experiment(:example)).to track(:my_event, value: 1, property: '_property_')
  .on_next_instance
  .with_context(foo: :bar)
  .for(:variant_name)
experiment(:example, :variant_name, foo: :bar).track(:my_event, value: 1, property: '_property_')
Assert the events an experiment emits
The track matcher asserts that the experiment was asked to track something. It does not see the payload that reaches Snowplow, and it cannot see events the browser sends at all.
To assert both, tag a feature spec with :capture_snowplow_events and declare the events each variant must emit in a tracking journey contract. The contract names the experiment once, so every event in the arm under test is also required to carry that experiment's context:
expect_snowplow_tracking_journey('my_experiment', variant: variant)
For the contract format and the rest of the mechanism, see Capturing Snowplow events in feature specs.
Test with Jest
Stub Helpers
You can stub experiments using the stubExperiments helper defined in spec/frontend/__helpers__/experimentation_helper.js.
import { stubExperiments } from 'helpers/experimentation_helper';
import { getExperimentData } from '~/experimentation/utils';
describe('when my_experiment is enabled', () => {
  beforeEach(() => {
    stubExperiments({ my_experiment: 'candidate' });
  it('sets the correct data', () => {
    expect(getExperimentData('my_experiment')).toEqual({ experiment: 'my_experiment', variant: 'candidate' });
This method of stubbing in Jest specs does not automatically un-stub itself at the end of the test. We merge our stubbed experiment in with all the other global data in window.gl. If you must remove the stubbed experiments after your test or ensure a clean global object before your test, you must manage the global object directly yourself:
describe('tests that care about global state', () => {
  const originalObjects = [];
  beforeEach(() => {
    // For backwards compatibility for now, we're using both window.gon & window.gl
    originalObjects.push(window.gon, window.gl);
  afterEach(() => {
    [window.gon, window.gl] = originalObjects;
  it('stubs experiment in fresh global state', () => {
    stubExperiment({ my_experiment: 'candidate' });
