GitLab instrumentation for OpenTelemetry
Enable OpenTelemetry tracing, metrics, and logs in GDK development
Currently the default GDK environment is not set up by default to properly
collect and display OpenTelemetry data. Therefore, you should point the
OTEL_EXPORTER_*_ENDPOINT ENV vars to a GitLab project:
- Which has an Ultimate license
- In which you have at least the Maintainer role
- In which you have access to enable top-level group feature flags (or is under the
gitlab-orgorgitlab-comtop-level groups which already have the flags enabled)
Once you have a project identified to use:
Note the ID of the project (from the three dots at upper right of main project page).
Note the ID of the top-level group which contains the project.
When setting the environment variables for the following steps, add them to
env.runitin the root of thegitlab-development-kitfolder. -
Follow instructions to configure distributed tracing for a project, with the following custom settings:
For the
OTEL_EXPORTER_OTLP_TRACES_ENDPOINTenvironment variable, use the following value:export OTEL_EXPORTER_OTLP_TRACES_ENDPOINT="https://<gitlab-host>/v3/<gitlab-top-level-group-id>/<gitlab-project-id>/ingest/traces"
Follow instructions to configure distributed metrics for a project, with the following custom settings:
For the
OTEL_EXPORTER_OTLP_METRICS_ENDPOINTenvironment variable, use the following value:export OTEL_EXPORTER_OTLP_METRICS_ENDPOINT="https://<gitlab-host>/v3/<gitlab-top-level-group-id>/<gitlab-project-id>/ingest/metrics"
Follow instructions to configure distributed logs for a project, with the following custom settings:
For the
OTEL_EXPORTER_OTLP_LOGS_ENDPOINTenvironment variable, use the following value:export OTEL_EXPORTER_OTLP_LOGS_ENDPOINT="https://<gitlab-host>/v3/<gitlab-top-level-group-id>/<gitlab-project-id>/ingest/logs"
Also add the following to the
env.runitfile:# GitLab-specific flag to enable the Rails initializer to set up OpenTelemetry exporters export GITLAB_ENABLE_OTEL_EXPORTERS=true -
gdk restart. -
Navigate to your project, and follow the instructions in the above docs to enable and view the tracing, metrics, or logs.
