Commit 94c8f21a authored by Deepak Rangarajan's avatar Deepak Rangarajan
Browse files
switch back to dockerhub, but using a docker account
parent f7b25118
Loading
Loading
Loading
Loading
+2 −1
Changes for .gitlab-ci.yml: 2 added lines, 1 removed line.
Original line number Original line Diff line number Diff line
@@ -17,7 +17,8 @@ build-img:
    entrypoint: [""]
    entrypoint: [""]
  script:
  script:
    - mkdir -p /kaniko/.docker
    - echo "{\"auths\":{\"$CI_REGISTRY\":{\"username\":\"$CI_REGISTRY_USER\",\"password\":\"$CI_REGISTRY_PASSWORD\"}}}" > /kaniko/.docker/config.json
    - DOCKER_AUTH=$(echo -n "$DOCKER_HUB_USR:$DOCKER_HUB_PASS" | base64)
    - echo "{\"auths\":{\"$CI_REGISTRY\":{\"username\":\"$CI_REGISTRY_USER\",\"password\":\"$CI_REGISTRY_PASSWORD\"},\"https://index.docker.io/v1/\":{\"auth\":\"$DOCKER_AUTH\"}}}" > /kaniko/.docker/config.json
    - /kaniko/executor --cache=true --context $CI_PROJECT_DIR --dockerfile ./Dockerfile --destination $CI_REGISTRY_IMAGE:latest
  tags:
  tags:
    - docker
    - docker
+1 −1
Changes for Dockerfile: 1 added line, 1 removed line.
# Docker Image for running csg-eb tests
FROM public.ecr.aws/lts/ubuntu:20.04
FROM ubuntu:20.04
LABEL maintainer="Mark Meredith <mark.meredith@netl.doe.gov>"
