| integer, parameter | quadric::dim_quadric = 500 |
| integer | quadric::n_quadric |
| integer | quadric::quadric_id |
| character(len=12), dimension(dim_quadric) | quadric::quadric_form |
| double precision | quadric::quadric_scale |
| double precision, dimension(dim_quadric) | quadric::lambda_x |
| double precision, dimension(dim_quadric) | quadric::lambda_y |
| double precision, dimension(dim_quadric) | quadric::lamb |
| double precision, dimension(dim_quadric) | quadric::dquadric |
| double precision, dimension(dim_quadric) | quadric::t_x |
| double precision, dimension(dim_quadric) | quadric::t_y |
| double precision, dimension(dim_quadric) | quadric::t_z |
| double precision, dimension(dim_quadric) | quadric::theta_x |
| double precision, dimension(dim_quadric) | quadric::theta_y |
| double precision, dimension(dim_quadric) | quadric::theta_ |
| double precision, dimension(dim_quadric) | quadric::radius |
| double precision, dimension(dim_quadric) | quadric::torus_r1 |
| double precision, dimension(dim_quadric) | quadric::torus_r2 |
| double precision, dimension(dim_quadric) | quadric::ucoil_r1 |
| double precision, dimension(dim_quadric) | quadric::ucoil_r2 |
| double precision, dimension(dim_quadric) | quadric::ucoil_y1 |
| double precision, dimension(dim_quadric) | quadric::ucoil_y2 |
| double precision, dimension(dim_quadric) | quadric::bend_r1 |
| double precision, dimension(dim_quadric) | quadric::bend_r2 |
| double precision, dimension(dim_quadric) | quadric::bend_theta1 |
| double precision, dimension(dim_quadric) | quadric::bend_thet |
| double precision, dimension(dim_quadric) | quadric::c2c_y1 |
| double precision, dimension(dim_quadric) | quadric::c2c_y2 |
| double precision, dimension(dim_quadric) | quadric::c2c_r1 |
| double precision, dimension(dim_quadric) | quadric::c2c_r2 |
| double precision, dimension(dim_quadric) | quadric::half_angle |
| double precision, dimension(dim_quadric) | quadric::reactor1_r1 |
| double precision, dimension(dim_quadric) | quadric::reactor1_r |
| double precision, dimension(dim_quadric) | quadric::reactor1_y1 |
| double precision, dimension(dim_quadric) | quadric::reactor1_y |
| double precision, dimension(dim_quadric) | quadric::reactor1_yr1 |
| double precision, dimension(dim_quadric) | quadric::reactor1_ |
| double precision, dimension(dim_quadric) | quadric::reactor1_rr1 |
| double precision, dimension(dim_quadric) | quadric::reactor1_theta1 |
| double precision, dimension(dim_quadric) | quadric::reacto |
| double precision, dimension(dim_quadric) | quadric::n_x |
| double precision, dimension(dim_quadric) | quadric::n_y |
| double precision, dimension(dim_quadric) | quadric::n_z |
| double precision, dimension(3, 3, dim_quadric) | quadric::a_quadric |
| double precision, dimension(1, 3, dim_quadric) | quadric::t_quadric |
| double precision, dimension(dim_quadric) | quadric::clip_xmin |
| double precision, dimension(dim_quadric) | quadric::clip_xmax |
| double precision, dimension(dim_quadric) | quadric::cl |
| double precision, dimension(dim_quadric) | quadric::piece_xmin |
| double precision, dimension(dim_quadric) | quadric::piece_xmax |
| logical, dimension(dim_quadric) | quadric::fluid_in_clipped_region |
| integer, dimension(dim_quadric) | quadric::bc_id_q |
| integer, parameter | quadric::dim_group = 50 |
| integer | quadric::n_group |
| integer, dimension(dim_group) | quadric::group_size |
| integer, dimension(dim_group, dim_quadric) | quadric::group_q |
| character(len=9), dimension(dim_group) | quadric::group_relation |
| character(len=9), dimension(dim_group) | quadric::relation_with_previous |
| double precision | quadric::tol_f |
| integer | quadric::itermax_int |
