Functions/Subroutines | |
| subroutine | closestptpointtriangle (pointp, points, closest_point) |
| subroutine | intersectlnplane (ref_line, dir_line, ref_plane, norm_plane, line_param) |
| subroutine | tri_box_overlap (pCENTER, pHALFSIZE, pVERTS, pOVERLAP) |
| subroutine | check_if_particle_overlaps_stl (POS, fI, fJ, fK, REMOVE) |
| subroutine stl_functions_des::check_if_particle_overlaps_stl | ( | double precision, dimension(dimn), intent(in) | POS, |
| integer, intent(in) | fI, | ||
| integer, intent(in) | fJ, | ||
| integer, intent(in) | fK, | ||
| logical, intent(out) | REMOVE | ||
Definition at line 432 of file stl_functions_des_mod.f.
| subroutine stl_functions_des::closestptpointtriangle | ( | double precision, dimension(dimn), intent(in) | pointp, |
| double precision, dimension(3,3), intent(in) | points, | ||
| double precision, dimension(dimn), intent(out) | closest_point | ||
| subroutine stl_functions_des::intersectlnplane | ( | double precision, dimension(3), intent(in) | ref_line, |
| double precision, dimension(3), intent(in) | dir_line, | ||
| double precision, dimension(3), intent(in) | ref_plane, | ||
| double precision, dimension(3), intent(in) | norm_plane, | ||
| double precision, intent(out) | line_param | ||
| subroutine stl_functions_des::tri_box_overlap | ( | double precision, dimension(3), intent(in) | pCENTER, |
| double precision, dimension(3), intent(in) | pHALFSIZE, | ||
| double precision, dimension(3,3), intent(in) | pVERTS, | ||
| logical, intent(out) | pOVERLAP | ||
Definition at line 161 of file stl_functions_des_mod.f.
