integer, dimension(dimension_ps) ps_i_w
integer, parameter dim_n_g
double precision, dimension(dimension_ps) ps_v_g
double precision, dimension(dimension_ps) ps_t_g
double precision, dimension(dimension_ps, dim_m) ps_v_s
double precision, dimension(dimension_ps) ps_vel_mag_g
integer, dimension(:), allocatable point_sources
double precision, dimension(dimension_ps, dim_m) ps_vel_mag_s
integer, dimension(dimension_ps) ps_j_n
double precision, dimension(dimension_ps) ps_y_n
double precision, dimension(dimension_ps) ps_cpxmflow_g
double precision, dimension(dimension_ps) ps_z_b
double precision, dimension(dimension_ps) ps_massflow_g
logical, dimension(dimension_ps) ps_defined
double precision, dimension(dimension_ps) ps_w_g
double precision, dimension(dimension_ps, dim_m) ps_t_s
double precision, dimension(dimension_ps) ps_x_e
double precision, dimension(dimension_ps) ps_x_w
double precision, dimension(dimension_ps) ps_volume
integer, dimension(dimension_ps) ps_k_b
double precision, dimension(dimension_ps, dim_m) ps_u_s
double precision, dimension(dimension_ps, dim_m) ps_cpxmflow_s
double precision, dimension(dimension_ps) ps_y_s
integer, dimension(dimension_ps) ps_k_t
double precision, dimension(dimension_ps, dim_n_g) ps_x_g
integer, parameter dimension_ps
double precision, dimension(dimension_ps, dim_m) ps_massflow_s
integer, parameter dim_n_s
double precision, dimension(dimension_ps) ps_z_t
double precision, dimension(dimension_ps, dim_m) ps_w_s
double precision, dimension(dimension_ps, dim_m, dim_n_s) ps_x_s
double precision, dimension(dimension_ps) ps_u_g
integer, dimension(dimension_ps) ps_j_s
integer, dimension(dimension_ps) ps_i_e
