Main Page
Modules
Data Types List
Files
File List
File Members
set_l_scale.f
!vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvC
! C
3
! Module name: SET_L_scale C
4
! Purpose: Initialize length scale for turbulence model C
5
! C
6
! Author: W. Sams Date: 04-MAY-94 C
7
! Reviewer: Date: dd-mmm-yy C
8
! C
! Literature/Document References: C
! C
11
! Variables referenced: C
12
! C
13
! Variables modified: L_scale0, L_scale C
14
! C
15
! Local variables: C
16
! C
17
!^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^C
18
19
SUBROUTINE
set_l_scale
20
!...Translated by Pacific-Sierra Research VAST-90 2.06G5 12:17:31 12/09/98
21
!...Switches: -xf
22
23
! Include param.inc file to specify parameter values
24
25
26
! M o d u l e s
27
28
USE
param
29
USE
param1
USE
parallel
31
USE
constant
32
USE
visc_g
33
USE
geometry
34
USE
indices
35
USE
compar
36
IMPLICIT NONE
37
38
! G l o b a l P a r a m e t e r s
39
40
41
! L o c a l P a r a m e t e r s
42
43
44
! L o c a l V a r i a b l e s
45
46
INTEGER
:: IJK
47
48
49
ijk = 1
50
51
! IF (IJKMAX2 > 0) THEN
52
l_scale
ijkstart3
ijkend3
l_scale0
53
! IJK = IJKMAX3 + 1
54
! ENDIF
55
RETURN
56
END SUBROUTINE
set_l_scale
57
58
!// Comments on the modifications for DMP version implementation
59
!// 001 Include header file and common declarations for parallelization
60
!// 120 Replaced the index for initialization : :IJKMAX2 --> L_SCALE(IJKSTART3:IJKEND3)
constant::l_scale0
double precision l_scale0
Definition:
constant_mod.f:177
param1
Definition:
param1_mod.f:2
compar::ijkend3
integer ijkend3
Definition:
compar_mod.f:80
constant
Definition:
constant_mod.f:20
compar
Definition:
compar_mod.f:12
indices
Definition:
indices_mod.f:9
parallel
Definition:
parallel_mod.f:3
visc_g::l_scale
double precision, dimension(:), allocatable l_scale
Definition:
visc_g_mod.f:24
param
Definition:
param_mod.f:2
compar::ijkstart3
integer ijkstart3
Definition:
compar_mod.f:80
visc_g
Definition:
visc_g_mod.f:1
set_l_scale
subroutine set_l_scale
Definition:
set_l_scale.f:20
geometry
Definition:
geometry_mod.f:11
set_l_scale.f
Generated by
1.8.11
