Main Page
Modules
Data Types List
Files
File List
File Members
set_geometry_des.f
!vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv!
3
! Subroutine: SET_GEOMETRY_DES !
4
! Author: R.Garg Date: 19-Mar-14 !
5
6
! Purpose: Allocate des arrays that are based on Eulerian grid. !
7
8
SUBROUTINE
set_geometry_des
11
12
! Global Variables:
13
14
! Arrays for DEM simulations delineating cell edges.
15
use
discretelement
, only
: xe, yn, zt, dimn
16
! Domain bounds (max/min).
17
use
discretelement
, only
: ex2, ty2, nz2, wx1, by1, sz1
18
! Fluid grid cell dimensions and mesh size
19
USE
geometry
, only
dx
imin2
imax2
20
USE
geometry
, only
dy
jmin2
jmax2
21
USE
geometry
, only
dz
kmin2
kmax2
22
! Number of particles in the I/J/K direction
23
use
param
, only
dimension_i
dimension_j
dimension_k
24
25
! Global Parameters:
26
27
use
param1
, only
zero
28
29
! Module proceedures.
31
use
mpi_utility
32
use
error_manager
33
34
IMPLICIT NONE
35
36
! Local Variables:
37
38
! Generic loop indices
39
INTEGER
:: I, J, K
40
! Error Flag
41
INTEGER
:: IER
42
43
44
! Initialize the error manager.
45
CALL
init_err_msg
"SET_GEOMETRY_DES"
46
47
Allocate
( xe(0:
dimension_i
), stat=ier )
48
Allocate
( yn(0:
dimension_j
), stat=ier )
49
Allocate
( zt(0:
dimension_k
), stat=ier )
50
51
! Collect the error flags from all ranks. If all allocaitons were
52
! successfull, do nothing. Otherwise, flag the error and abort.
53
CALL
global_all_sum
(ier)
54
55
56
! Set boundary edges.
57
! In some instances wx1,ex2, etc have been used and in others
58
! xlength,zero, etc are used. the code should be modified for
59
! consistency throughout
60
ex2 = xlength; wx1 =
zero
! East/West
61
ty2 = ylength; by1 =
zero
! North/South
62
nz2 = zlength; sz1 =
zero
! Top/Bottom
63
64
! Initialize arrays.
65
xe(:) =
zero
66
yn(:) =
zero
67
zt(:) =
zero
68
69
! Each loop starts at 2 and goes to max+2 (i.e., imin1=2, imax2=imax+2)
70
! However, the indices range to include ghost cells (0-imax2) to avoid
71
! multiple if statements in particles_in_cell
72
xe(imin2-1) =
zero
-dx(imin2)
73
DO
i = imin2, imax2
74
xe(i) = xe(i-1) + dx(i)
75
ENDDO
76
77
yn(jmin2-1) =
zero
-dy(jmin2)
78
DO
j = jmin2, jmax2
79
yn(j) = yn(j-1) + dy(j)
80
ENDDO
81
82
IF
(dimn.EQ.3)
THEN
83
zt(
kmin2
-1) =
zero
dz
kmin2
84
DO
k =
kmin2
kmax2
85
zt(k) = zt(k-1) +
dz
(k)
86
ENDDO
87
ENDIF
88
89
CALL
finl_err_msg
90
91
RETURN
92
END SUBROUTINE
set_geometry_des
mpi_utility
Definition:
mpi_utility_mod.f:6
param::dimension_i
integer dimension_i
Definition:
param_mod.f:7
geometry::imax2
integer imax2
Definition:
geometry_mod.f:61
param1
Definition:
param1_mod.f:2
error_manager::finl_err_msg
subroutine finl_err_msg
Definition:
error_manager_mod.f:216
param::dimension_k
integer dimension_k
Definition:
param_mod.f:9
geometry::dy
double precision, dimension(0:dim_j) dy
Definition:
geometry_mod.f:70
geometry::dz
double precision, dimension(0:dim_k) dz
Definition:
geometry_mod.f:72
geometry::jmin2
integer jmin2
Definition:
geometry_mod.f:89
error_manager::init_err_msg
Definition:
error_manager_mod.f:171
set_geometry_des
subroutine set_geometry_des
Definition:
set_geometry_des.f:10
geometry::jmax2
integer jmax2
Definition:
geometry_mod.f:63
geometry::dx
double precision, dimension(0:dim_i) dx
Definition:
geometry_mod.f:68
geometry::kmax2
integer kmax2
Definition:
geometry_mod.f:65
mpi_utility::global_all_sum
Definition:
mpi_utility_mod.f:66
param
Definition:
param_mod.f:2
geometry::imin2
integer imin2
Definition:
geometry_mod.f:89
error_manager
Definition:
error_manager_mod.f:8
geometry
Definition:
geometry_mod.f:11
param1::zero
Definition:
param1_mod.f:27
geometry::kmin2
integer kmin2
Definition:
geometry_mod.f:89
param::dimension_j
integer dimension_j
Definition:
param_mod.f:8
des
set_geometry_des.f
Generated by
1.8.11
