multisap.f
2 ! !
3 ! Module: multi_sweep_and_prune !
4 ! !
5 ! Purpose: Divides space into a grid of sap_t instances and adds !
6 ! AABB's to the corresponding sap_t instance(s) !
7 ! !
8 ! Reference: http://www.codercorner.com/SAP.pdf !
9 ! !
10 !^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^!
11
12 #include "version.inc"
13
15
16  use sweep_and_prune
17
19  ! grid particle, e.g. 20x20x20
20  integer :: grid(3)
21
22  ! bounds of the grid (grid saps on the boundary extend to infinity)
23  real :: minbounds(3), maxbounds(3)
24
25  ! grid(:)/(maxbounds(:)-minbounds(:))
26  real :: one_over_cell_length(3)
27
28  ! list saps of length grid(1)*grid(2)*grid(3)
29  type(sap_t), dimension(:), allocatable :: saps
31  ! union of all hashtables for all saps in this multisap
32  type(hashtable_t) :: hashtable
33  end type multisap_t
34
35  !vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv!
36  ! !
37  ! Type: boxhandle_t !
38  ! !
39  ! Purpose: Represents a reference to a particle box in a particular !
40  ! sap for this multisap. !
41  ! !
42  !^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^!
43
45  integer :: sap_id
46  integer :: box_id
47  end type boxhandle_t
48
49  !vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv!
50  ! !
51  ! Type: boxhandlelist_t !
52  ! !
53  ! Purpose: List of boxhandle_t instances that corresponding to a !
54  ! particular particle with id particle_id. !
55  ! !
56  !^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^!
57
58  ! The maximum number of saps an aabb can belong to. For 2d this could be 4,
59  ! but no harm in just setting it to 8.
60  integer, parameter :: max_saps = 8
61
63  integer :: particle_id
65  end type boxhandlelist_t
66
68  private :: multisap_raster
69
70 contains
71  !vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv!
72  ! !
73  ! Subroutine: init_sap !
74  ! !
75  ! Purpose: multisap_t constructor !
76  ! !
77  !^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^!
78
79  subroutine init_multisap(this,x_grid,y_grid,z_grid2,minbounds,maxbounds)
81  implicit none
82  type(multisap_t), intent(inout) :: this
83  integer, intent(in) :: x_grid,y_grid, z_grid2
84  real, dimension(3), intent(in) :: minbounds, maxbounds
85  integer :: ii,jj,kk, z_grid, sap_id
86
87  if (no_k) then
88  z_grid = 1
89  else
90  z_grid = z_grid2
91  endif
92
93  this%grid(1) = max(x_grid,1)
94  this%grid(2) = max(y_grid,1)
95  this%grid(3) = max(z_grid,1)
96
97  allocate(this%saps(0:this%grid(1)*this%grid(2)*this%grid(3)-1))
98  do ii=0,this%grid(1)-1
99  do jj=0,this%grid(2)-1
100  do kk=0,this%grid(3)-1
101  sap_id = (ii*this%grid(2)+jj)*this%grid(3)+kk
102  call init_sap(this%saps(sap_id),sap_id)
103  enddo
104  enddo
105  enddo
106
107  this%one_over_cell_length(:) = this%grid(:)/(maxbounds(:)-minbounds(:))
108
109  this%minbounds(:) = minbounds(:)
110  this%maxbounds(:) = maxbounds(:)
111
112  end subroutine init_multisap
113
114  !vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv!
115  ! !
116  ! Subroutine: multisap_raster !
117  ! !
118  ! Purpose: For a given aabb, return the list sap_ids of ids of the !
119  ! saps that the aabb intersects according to the grid. !
120  ! Used by multisap_add and multisap_del. !
121  ! !
122  !^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^!
123
124  subroutine multisap_raster(this,aabb,sap_ids)
125  implicit none
126  type(multisap_t), intent(inout) :: this
127  type(aabb_t), intent(in) :: aabb
128  integer, intent(out) :: sap_ids(max_saps)
129  integer :: max_grid(3),min_grid(3)
130
131  sap_ids(:) = -1
132
133  ! bin to grid
134  min_grid(:) = floor((aabb%minendpoint(:)-this%minbounds(:))*this%one_over_cell_length(:))
135  max_grid(:) = floor((aabb%maxendpoint(:)-this%minbounds(:))*this%one_over_cell_length(:))
136
137  min_grid(1) = min(max(min_grid(1),0),this%grid(1)-1)
138  min_grid(2) = min(max(min_grid(2),0),this%grid(2)-1)
139  min_grid(3) = min(max(min_grid(3),0),this%grid(3)-1)
140  max_grid(1) = min(max(max_grid(1),0),this%grid(1)-1)
141  max_grid(2) = min(max(max_grid(2),0),this%grid(2)-1)
142  max_grid(3) = min(max(max_grid(3),0),this%grid(3)-1)
143
144  call add_to_set((min_grid(1)*this%grid(2) + min_grid(2))*this%grid(3) + min_grid(3))
145  call add_to_set((min_grid(1)*this%grid(2) + min_grid(2))*this%grid(3) + max_grid(3))
146  call add_to_set((min_grid(1)*this%grid(2) + max_grid(2))*this%grid(3) + min_grid(3))
147  call add_to_set((min_grid(1)*this%grid(2) + max_grid(2))*this%grid(3) + max_grid(3))
148  call add_to_set((max_grid(1)*this%grid(2) + min_grid(2))*this%grid(3) + min_grid(3))
149  call add_to_set((max_grid(1)*this%grid(2) + min_grid(2))*this%grid(3) + max_grid(3))
150  call add_to_set((max_grid(1)*this%grid(2) + max_grid(2))*this%grid(3) + min_grid(3))
151  call add_to_set((max_grid(1)*this%grid(2) + max_grid(2))*this%grid(3) + max_grid(3))
152
153  contains
154
155  !vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv!
156  ! !
157  ! Subroutine: add_to_set !
158  ! !
159  ! Purpose: Add sap_id to sap_ids if it's not already in there. !
160  ! !
161  !^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^!
162
163  subroutine add_to_set(sap_id)
164  integer, intent(in) :: sap_id
165  integer :: mm
166
167  do mm=1, size(sap_ids)
168  if (sap_ids(mm).eq.sap_id) then
169  ! already in the list
170  return
171  endif
172  if (sap_ids(mm).eq.-1) then
173  sap_ids(mm) = sap_id
174  return
175  endif
176  enddo
177
178  end subroutine add_to_set
179
180  end subroutine multisap_raster
181
182  !vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv!
183  ! !
184  ! Subroutine: multisap_add !
185  ! !
186  ! Purpose: Add boxes in appropriate saps for aabb representing !
187  ! particle_id and return list of (sap_id,box_id) handles !
188  ! in handlelist. !
189  ! !
190  !^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^!
191
192  subroutine multisap_add(this,aabb,particle_id,handlelist)
193  implicit none
194  type(multisap_t), intent(inout) :: this
195  type(aabb_t), intent(in) :: aabb
196  integer, intent(in) :: particle_id
197  type(boxhandlelist_t), intent(out) :: handlelist
198  integer :: sap_ids(max_saps)
199  integer :: nn
200
201  call multisap_raster(this,aabb,sap_ids)
202
203  handlelist%particle_id = particle_id
204
205  ! add to each individual SAP
206  do nn=1, size(sap_ids)
207  handlelist%list(nn)%sap_id = sap_ids(nn)
208  if (sap_ids(nn) >= 0) then
209  call add_box(this%saps(sap_ids(nn)),aabb,particle_id,handlelist%list(nn)%box_id)
210  endif
211  enddo
212
213  end subroutine multisap_add
214
215  !vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv!
216  ! !
217  ! Subroutine: multisap_del !
218  ! !
219  ! Purpose: Delete all sap entries corresponding to handlelist. !
220  ! !
221  !^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^!
222
223  subroutine multisap_del(this,handlelist)
224  implicit none
225  type(multisap_t), intent(inout) :: this
226  type(boxhandlelist_t), intent(in) :: handlelist
227  integer :: nn
228
229  ! remove from each SAP listed for this id
230  do nn=1, size(handlelist%list)
231  if (handlelist%list(nn)%sap_id >= 0) then
232  call del_box(this%saps(handlelist%list(nn)%sap_id),handlelist%list(nn)%box_id)
233  endif
234  enddo
235
236  end subroutine multisap_del
237
238  !vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv!
239  ! !
240  ! Subroutine: multisap_update !
241  ! !
242  ! Purpose: Update the sap entries corresponding to handlelist with !
243  ! new location aabb. Returns an updated handlelist with !
244  ! possibly different sap entries. !
245  ! !
246  !^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^!
247
248  subroutine multisap_update(this,aabb,handlelist)
249  implicit none
250  type(multisap_t), intent(inout) :: this
251  type(aabb_t), intent(in) :: aabb
252  type(boxhandlelist_t), intent(inout) :: handlelist
253  integer, DIMENSION(MAX_SAPS) :: new_sap_ids
254  logical :: found
255  integer :: mm,nn,first_blank, box_id
256
257  call multisap_raster(this,aabb,new_sap_ids)
258
259  ! update for each SAP listed for this id
260  do nn=1, size(new_sap_ids)
261  if (new_sap_ids(nn) < 0) exit
262
263  found = .false.
264  first_blank = -1
265  do mm=1, size(handlelist%list)
266  if (handlelist%list(mm)%sap_id < 0) first_blank = mm
267
268  if (handlelist%list(mm)%sap_id .eq. new_sap_ids(nn)) then
269  ! update existing SAPs
270  box_id = handlelist%list(mm)%box_id
271  call update_box(this%saps(new_sap_ids(nn)),handlelist%list(mm)%box_id,aabb)
272  found = .true.
273  exit
274  endif
275  enddo
276  if (.not.found) then
277  ! add SAPs yet not listed for this id
278
279  if (first_blank .eq. -1) then
280  print *,"AABB is in more than 8 saps? Something is wrong: ",first_blank,handlelist%list
281  error_stop __line__
282  endif
283  call add_box(this%saps(new_sap_ids(nn)),aabb,handlelist%particle_id,handlelist%list(first_blank)%box_id)
284  handlelist%list(first_blank)%sap_id = new_sap_ids(nn)
285  endif
286  enddo
287
288  do mm=1, size(handlelist%list)
289  if (handlelist%list(mm)%sap_id < 0) cycle
290
291  found = .false.
292  do nn=1, size(new_sap_ids)
293  if (new_sap_ids(nn) < 0) exit
294
295  if (handlelist%list(mm)%sap_id .eq. new_sap_ids(nn)) then
296  found = .true.
297  exit
298  endif
299  enddo
300
301  if (.not.found) then
302  ! remove SAP not found in handle%sap_id
303  call del_box(this%saps(handlelist%list(mm)%sap_id),handlelist%list(mm)%box_id)
304  handlelist%list(mm)%sap_id = -1
305  endif
306
307  enddo
308
309  end subroutine multisap_update
310
311  !vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv!
312  ! !
313  ! Subroutine: multisap_sort !
314  ! !
315  ! Purpose: Call sort on each of the saps in this multisap, !
316  ! then set the multisap's hashtable to the union of the !
317  ! hashtables of all the saps. !
318  ! !
319  !^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^!
320
321  subroutine multisap_sort(this)
322  ! use discretelement
323  ! use functions, only: is_nonexistent
324  implicit none
325  type(multisap_t), intent(inout) :: this
326  integer :: ii, jj, kk, sap_id
327  integer :: pair(2)
328  integer :: sighs, cc,ll,i, cc_start, cc_end
329
330  call init_pairs(this%hashtable)
331
332 !$omp parallel default(none) private(ii,jj,kk,sap_id,pair) shared(this)
333 !$omp do collapse(3)
334  do ii=0,this%grid(1)-1
335  do jj=0,this%grid(2)-1
336  do kk=0,this%grid(3)-1
337  sap_id = ii*this%grid(2)*this%grid(3)+jj*this%grid(3)+kk
338  call sort(this%saps(sap_id))
339  enddo
340  enddo
341  enddo
342 !$omp end parallel
343
344  print *," NUMBER OF DESGRIDS IS: ",this%grid(1)*this%grid(2)*this%grid(3)
345
346  sighs = 0
347
348  open (unit=235,file="pairs.txt",action="write",status="replace")
349
350  do ii=0,this%grid(1)-1
351  do jj=0,this%grid(2)-1
352  do kk=0,this%grid(3)-1
353  sap_id = ii*this%grid(2)*this%grid(3)+jj*this%grid(3)+kk
354  call reset_pairs(this%saps(sap_id)%hashtable)
355  sighs = sighs + this%saps(sap_id)%hashtable%table_size
356  do
357  call get_pair(this%saps(sap_id)%hashtable,pair)
358  if (pair(1).eq.0 .and. pair(2).eq.0) exit
359  write (235,*) pair(1),pair(2)
360  call add_pair(this%hashtable,pair(1),pair(2))
361
362  enddo
363  enddo
364  enddo
365  enddo
366
367  close (unit=235)
368
369  ! call reset_pairs(this%hashtable)
370
371  ! do
372  ! call get_pair(this%hashtable,pair)
373  ! if (pair(1).eq.0 .and. pair(2).eq.0) exit
374  ! write (235,*) pair(1),pair(2)
375  ! enddo
376
377  ! print *,"multisize ",this%hashtable%table_size
378  ! print *,"sighs ",sighs
379  ! stop __LINE__
380
381  end subroutine multisap_sort
382
383  !vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv!
384  ! !
385  ! Subroutine: multisap_add !
386  ! !
387  ! Purpose: Call quicksort on each of the saps in this multisap. !
388  ! !
389  !^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^!
390
391  subroutine multisap_quicksort(this)
392  implicit none
393  type(multisap_t), intent(inout) :: this
394  integer :: ii, jj, kk
395  integer :: sap_id, boxcount
396
397  boxcount = 0
398
399  do ii=0,this%grid(1)-1
400  do jj=0,this%grid(2)-1
401  do kk=0,this%grid(3)-1
402  sap_id = ii*this%grid(2)*this%grid(3)+jj*this%grid(3)+kk
403  call quicksort(this%saps(sap_id))
404  boxcount = boxcount + this%saps(sap_id)%boxes_len
405  enddo
406  enddo
407  enddo
408
409  end subroutine multisap_quicksort
410
411  !vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv!
412  ! !
413  ! Subroutine: multisap_sweep !
414  ! !
415  ! Purpose: Call sweep on each of the saps in this multisap. !
416  ! !
417  !^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^!
418
419  subroutine multisap_sweep(this)
420  implicit none
421  type(multisap_t), intent(inout) :: this
422  integer :: ii, jj, kk
423  integer :: sap_id
424
425  do ii=0,this%grid(1)-1
426  do jj=0,this%grid(2)-1
427  do kk=0,this%grid(3)-1
428  sap_id = (ii*this%grid(2)+jj)*this%grid(3)+kk
429  call sweep(this%saps(sap_id))
430  enddo
431  enddo
432  enddo
433
434  end subroutine multisap_sweep
435
436  subroutine multisap_check(this)
437  implicit none
438  type(multisap_t), intent(inout) :: this
439  integer :: ii, jj, kk
440  integer :: sap_id
441
442  do ii=0,this%grid(1)-1
443  do jj=0,this%grid(2)-1
444  do kk=0,this%grid(3)-1
445  sap_id = (ii*this%grid(2)+jj)*this%grid(3)+kk
446
447  call check(this%saps(sap_id))
448  enddo
449  enddo
450  enddo
451
452  end subroutine multisap_check
453
454  !vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv!
455  ! !
456  ! Subroutine: boxhandle_GROW !
457  ! !
458  ! Purpose: resize array of box_t !
459  ! !
460  !^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^!
461
462  subroutine boxhandle_grow(boxhandles,new_size)
463  IMPLICIT NONE
464
465  INTEGER, INTENT(IN) :: new_size
466  type(boxhandlelist_t), DIMENSION(:), ALLOCATABLE, INTENT(INOUT) :: boxhandles
467  type(boxhandlelist_t), DIMENSION(:), ALLOCATABLE :: boxhandle_tmp
468  INTEGER lSIZE
469
470  lsize = size(boxhandles,1)
471  allocate(boxhandle_tmp(new_size))
472  boxhandle_tmp(1:lsize) = boxhandles(1:lsize)
473  call move_alloc(boxhandle_tmp,boxhandles)
474
475  end subroutine boxhandle_grow
476
477 end module multi_sweep_and_prune
subroutine, public update_box(this, id, aabb)
Definition: sap.f:362
Definition: multisap.f:437
subroutine, public multisap_add(this, aabb, particle_id, handlelist)
Definition: multisap.f:193
subroutine, public multisap_update(this, aabb, handlelist)
Definition: multisap.f:249
subroutine, public multisap_sort(this)
Definition: multisap.f:322
subroutine, public boxhandle_grow(boxhandles, new_size)
Definition: multisap.f:463
subroutine, public sweep(this)
Definition: sap.f:438
subroutine, public multisap_sweep(this)
Definition: multisap.f:420
Definition: list.f:3
subroutine, public init_sap(this, id)
Definition: sap.f:190
subroutine, public add_box(this, aabb, particle_id, id)
Definition: sap.f:267
subroutine sort(Array, NUM_ROWS, COL1, COL2)
logical no_k
Definition: geometry_mod.f:28
Definition: multisap.f:164
subroutine quicksort(this)
Definition: sap.f:594
integer, parameter max_saps
Definition: multisap.f:60
subroutine, public del_box(this, id)
Definition: sap.f:340
subroutine, public init_multisap(this, x_grid, y_grid, z_grid2, minbounds, maxbounds)
Definition: multisap.f:80
subroutine, public multisap_quicksort(this)
Definition: multisap.f:392
subroutine, public multisap_del(this, handlelist)
Definition: multisap.f:224
