4.2. Geometry
The Geometry pane is used to define the model geometry. This includes whether the model is 2D or 3D, and the overall domain extents (xmin, xmax, ymin, ymax, zmin, zmax). If there is complex geometry, the “Auto-size” button can automatically set the extents to surround the geometry.
The geometry section provides tools for adding geometry objects (from STL files, or primitive elements), filters to transform geometry objects, and wizards to automate creating common complex geometries. Geometry objects can be copied, removed, or combined using Boolean operations. All the geometry operations are done using the Visualization Toolkit (VTK)’s library.
Geometry toolbar icons:
Icon
geometry
Add geometry to model
filter
Modify selected geometry with filter
wizard
Add geometry from wizard
remove
Remove the selected geometry
copy
Add duplicate of the selected geometry (copy/paste)
union
Add union of two or more selected geometries
intersect
Add intersection of two or more selected geometries
difference
Add difference of two or more selected geometries
In the geometry tree, the geometry object is displayed with the following icons:
Icon
Geometry Type
geometry
polydata
function
implicit
filter
filter
union
union
intersect
intersect
difference
difference
4.2.1. Adding Geometry
To add a Geometry object, click on the geometry (Geometry) icon and select the geometry to add from the drop-down menu.
There are two types of geometric objects supported in the GUI: implicit functions (quadrics), and objects defined by polydata (everything else: STL files, procedural shapes, primitives, parametrics, wizard geometry).
The following geometric objects can be added:
  • STL files (select a *.stl file from a file dialog)
  • Procedural shapes (cylinder, bend)
  • Implicit (Quadric) functions (sphere, box, cylinder, cone, quadric, superquadric)
  • Primitives (sphere, box, cylinder, cone)
  • Parametrics (torus, boy, conic spiral, etc.)
4.2.2. Procedural shapes
Procedural shapes were introduced in the 21.1 release. These are triangulated polydata objects that are defined by a series of parameters. They offer better control on the triangles quality than implicits or primitives.
4.2.2.1. Cylinder
Procedural cylinder
Parameters:
  • Radius (R)
  • Height (H)
  • Number of divisions along the height
  • Starting angle in the circumferential direction
  • Ending angle in the circumferential direction
  • Number of divisions along the circumferential direction
  • Bottom cap
  • Number of divisions in the bottom cap’s radial direction
  • Top cap
  • Number of divisions in the top cap’s radial direction
The top and bottom caps are shaped like fans, i.e., they converge radially towards the center of the cap. Caps are not needed if the cylinder extends past the MFiX domain in the axial direction, when inlet/outlet boundary conditions are defined along the MFiX box (say at y=ymin and y=ymax for a vertical cylinder).
It is recommended to include caps when combining shapes (union, intersection, difference) since the boolean operations are more robust with closed shapes.
4.2.2.2. Bend
Procedural cylinder
Front section:
  • Length (L f)
  • Radius (R f)
  • Number of divisions along the front section length
Back section:
  • Length (L b)
  • Radius (R b)
  • Number of divisions along the back section length
Bend section:
  • Major radius (R M)
  • Minor radius (R m)
  • Starting angle (\({\theta}\) f)
  • Ending angle (\({\theta}\) b)
  • Number of divisions in the angular direction
Circumference:
Caps:
  • Bottom cap
  • Top cap
4.2.3. Applying Filters
To apply a filter to the selected geometry, select a filter from the Filter menu. The filter options can be edited in the parameter section. The following filters are included:
Filter
vtk class
sample implicit
converts an implicit function to polydata
vtkSampleFunction
transform
rotate, scale, translate polydata
vtkTransformPolyDataFilter
clean
merge duplicate points and remove unused points and degenerate cells
vtkCleanPolyData
fill holes
fill holes
vtkFillHolesFilter
triangle
make sure all polys are triangles
vtkTriangleFilter
decimate
reduce the number of triangles
vtkDecimatePro
quadric decimation
vtkQuadricDecimation
quadric clustering
vtkQuadricClustering
linear subdivision
subdivide based on a linear scheme
vtkLinearSubdivisionFilter
loop subdivision
subdivide based on the Loop scheme
vtkLoopSubdivisionFilter
butterfly subdivision
subdivide based on 8-point butterfly scheme
vtkButterflySubdivisionFilter
smooth
move points based on Laplacian smoothing
vtkSmoothPolyDataFilter
windowed sinc
move points based on a windowed sinc function interpolation kernel
vtkWindowedSincPolyDataFilter
reverse sense
reverse order and/or normals of triangles
vtkReverseSense
Refer to the VTK website for details.
4.2.4. Wizards
Three wizards are available to more easily create common multiphase flow geometries: cyclones, reactors, and hoppers. A special “distributed” wizard is used to distribute one geometry inside another geometry with random, cubic, or body centered cubic positions. Random rotations can also be applied with the wizard.
cyclone wizard hopper wizard reactor wizard
4.2.5. Remove & Copy
To remove a selected geometry, click the remove (Remove) button. If a geometry is grouped as part of a Boolean Operation, removing it is disabled until that Boolean Operation is removed first.
To duplicate the selected geometry, click the copy (Duplicate) button. If multiple geometry objects are selected, duplication is disabled.
4.2.6. Boolean Operation
There are two types of geometric objects supported in the GUI: implicit functions (quadrics) and objects defined by polydata (everything else: STL files, primitives, parametrics, wizard geometry). Boolean operations cannot be performed between polydata and implicit geometry objects; the implicit function needs to be converted to polydata by using the sample implicit filter. Converting the implicit function also needs to be done in order for the GUI to export a STL file that the mfixsolver can use.
Boolean operations can only be performed with geometry objects of the same type (implicit, polydata). Boolean operations can not be performed between polydata and implicit geometry objects. If an implicit and a polydata must be managed together, the implicit object must be first converted to a polydata object using the sample implicit filter.
Boolean operation between two polydata objects is supported by MFiX, but for complex objects the VTK library may crash.
