6.2. Running Custom Interactive Solver¶
First build a custom solver.
6.2.1. Running Custom Solver From GUI¶
display the Run Dialog. Select the mfixsolver file you have just built.
6.2.2. Running Custom Solver From Command Line¶
As an example, the tfm/silane_pyrolysis_2d
default solver.
After building the solver, on a Linux or Mac system, run the custom solver with the command:
~/projectdir> ./mfixsolver -f SP2D.mfx
Use ./
in front of mfixsolver to use the solver in the project directory, not the default solver in your PATH
On Windows, run the custom solver in the project directory with:
C:\projectdir > mfixsolver -f SP2D.mfx
