6.1. Default Interactive Solver¶
when following the steps in Getting Started.
6.1.1. Running in GUI¶
Start the MFiX GUI from the Anaconda Prompt (Windows) or bash (Mac or Linux):
# Windows
(mfix-21.2) C:\> mfix
# Linux
(mfix-21.2) > mfix
# Mac
(mfix-21.2) > mfix
When running a simulation, press (run) and select the default mfixsolver.
6.1.2. Running From Command Line¶
If you have a project file <RUN_NAME>.mfx saved in a project directory named
<RUN_NAME>, navigate to that project directory to launch the default solver locally.
One can accomplish this with the following commands:
> cd <RUN_NAME>
> mfixsolver -f <RUN_NAME>.mfx
For example, to run the 3D fluidized bed tutorial, with the project file
FB3D.mfx created in the GUI and saved in a directory FB3D:
> cd FB3D
> mfixsolver -f FB3D.mfx
> mfixsolver --help
