3.8. SMS meshing workflow, cyclone, Discrete Element Model (DEM)¶
The SMS workflow is currently available as a beta testing feature, and can
be turned on from the settings menu (select SMS: Segregated Mesher/Solver (beta)
from the Mesher workflow drop down list). The blank template will automatically
3.8.1. Create a new project¶
On the main menu click on the
New button.
3.8.2. Import the geometry¶
Go to the Geometry pane:
Choose
STL fileas the geometry input.
cyclone.stl, select it and answerYeswhen prompted to copy the file to the project directory.Verify the STL normals are pointing in the right direction. In the model window, show the Geometry, hide the Background Mesh, Hide the Regions (visibility is toggled by clicking on each icon). Set the Geometry style to
edges, opacity to 1.0, check theShow normalsbox, set theScaleto 0.05, setcountto 10,000 (to show all normals).
Check the Flip normals box and notice the difference in the Model view. Uncheck the box since the original STL
file was correctly oriented.
In
Domain extent, click on Autosize, and adjust the following:Enter
0.0for the Min Y value.Enter
0.9for the Max Y value.Enter
0.25for the Max Z value.
button.
3.8.3. Create boundary conditions regions¶
Here, we need to define the mesh boundaries. Boundaries include the cyclone wall (curved surface defined by the STL geometry), and the inlet and outlets, defined along the domain outer box (plane boundaries). A Boundary Condition type must be defined, but it will be possible to change it later (in Modeler Tab). The actual boundary conditions (like the inlet velocity, or outlet pressure) do not need to be set at this point.
Go to the Regions pane:
There is already a
button to create a new region to be used by pressure outflow boundary condition.
Pressure outflowin the Boundary type drop down menu.Enter a name for the region in the Name field (“Top outlet”).
Change the region Color to Blue.
button to create a new region to be used by another pressure outflow boundary condition.
Pressure outflowin the Boundary type drop down menu.Enter a name for the region in the Name field (“Bottom outlet”).
Change the region Color to Yellow.
button to create a new region to be used by mass inflow boundary condition.
Mass inflowin the Boundary type drop down menu.Enter a name for the region in the Name field (“Front inlet”).
Change the region Color to Red.
click the
button to create a new region that covers the entire domain to be used for the wall boundary condition.
No-slip wallin the Boundary type drop down menu.Enter a name for the region in the Name field (“Wall”).
Change the region Color to Green.
Select facets (STL)andcyclone.stl, useallfor the selection method. You should see that there are 7554 facets selected.
The pressure outlet and mass inflow boundaries are located along the domain box. They are defined as rectangular 2D regions and must overlap the actual boundary areas (intersection of the STL file with the box planes). The exact boundary area will be computed automatically when preprocessing is performed. Since there is only one Boundary condition on the Top, Bottom and Front planes, we could also have used the entire planes instead of adjusting the region coordinates.
button.
3.8.4. Setup the mesh¶
25for the x cell value.Enter
70for the y cell value.Enter
33for the z cell value.
Generate. Select the default solver, and clickRunLook at the console output to verify the mesh generation completed successfully.
In the Model view, hide the Geometry, Background Mesh and Regions, show the Boundary_Mesh, set Color by to
bc_id, Style toedgesand opacity to1.0.The Boundary_Mesh should look like a closed surface with colors matching the Boundary Conditions regions.
Color the Boundary_Mesh by
small_cell. This will show small cells, as defined by the Small cell tolerance. The default value of 0.01 means a cut cell is considered small if its volume is below 0.01 times the volume of the corresponding standard, uncut cell. These small cells will be removed from the computation. Having a Small cell tolerance set to 0.0 will keep all small cells and this may lead to numerical stiffness and loss of convergence.
Mesh statistics (histogram) can be viewed in the Mesh Stats viewport. Various quantities are available. For example the aspect ratio of cut cells is between 1 and 8, with most aspect ratios between 1 and 2. This is acceptable.
Go back to the Geometry pane, and flip the normals. This will incorrectly orient the STL file. This is a common error when importing STL files. Generate the mesh and visualize the Boundary_Mesh. Having an open surface and boundaries inside-out is an indication that the normals are not properly oriented. The mesh should not be accepted.
Uncheck the
Flip normalsbox in the Geometry pane to get correct orientation. Go to the Region pane, and select the Front inlet region in the region table and set the Boundary type toNone. Save the project and generate the mesh. The Boundary_Mesh will look like an open surface, this is an indication a Boundary condition is missing. The mesh should not be accepted.
Remember to set the Front inlet Region boundary type to Mass inflow again before continuing.
3.8.5. Model settings¶
3.8.6. Regions settings¶
We already have the Background_IC region that is predefined. We will use it to initialize the flow field. We have defined all Boundary Condition regions during the meshing step. There are no other regions that need to be defined in this tutorial. We will re-use Background_IC region for the VTK output file.
3.8.7. Fluid settings¶
Change Density to
3.8.8. Solids settings¶
button to create a new solid.
Namefield (“Glass beads”).Verify the solids model is already set to “Discrete Element Model (MFiX-DEM)”.
2500kg/m3 in theDensityfield.
Enable automatic particle generationcheckbox. Although we will start with an empty cyclone, this setting is necessary so we don’t attempt to read initial particle location fromparticle_input.dat.Keep all other settings at their default values.
3.8.9. Initial Conditions settings¶
There is already a pre-defined “Background IC” region. This will initialize the entire flow field with air at rest.
3.8.10. Boundary Conditions settings¶
The Top outlet and Bottom outlet Boundary Conditions are already set to atmospheric pressure. No changes are needed.
3.8.11. Numerics settings¶
On the Numerics pane:
3.8.12. Output settings¶
Basicsub-pane, check theWrite VTK output files (VTU/VTP)checkbox.
button.
OKto create the output.
DiameterandTranslational Velocitycheck-boxes.
3.8.13. Run settings¶
Set the Stop time to
1.0.Set the Time step to
0.01.Set the Maximum time step to
0.01.Keep all other settings at their default values.
3.8.14. Run the simulation¶
button.
3.8.15. View results¶
next to the Model tab.
, and
buttons.
section on the sidebar.
