3.2. Two Dimensional Fluid Bed, Two Fluid Model (TFM)¶
This tutorial shows how to create a two dimensional fluidized bed simulation using the two fluid model. The model setup is:
10 cm x 30 cm |
20 x 60 |
0.25 m/s |
3.2.1. Create a new project¶
fig_new_project): On the main menu selectNew projectCreate a new project by double-clicking on “Blank” template.
Solverdrop-down menu.
3.2.3. Enter the geometry¶
2 DimensionalcheckboxEnter
3.2.4. Enter the mesh¶
20for the x cell valueEnter
60for the y cell value
visualize the results.
click the
button to create a new region to be used for the bed initial condition.
ColorbuttonEnter
xmaxormaxin theTo XfieldEnter
zmaxormaxin theTo Zfield
button to create a new region with the
FromandTofields already filled out for a region at the bottom of the domain, to be used by the gas inlet boundary condition.From YandTo Yshould equalymin, defining an XZ-plane.Enter a name for the region in the
Namefield (“inlet”)
FromandTofields already filled out for a region at the top of the domain, to be used by the pressure outlet boundary condition.From YandTo Yshould equalymax, defining an XZ-plane.Enter a name for the region in the
Namefield (“outlet”)
3.2.6. Create a solid¶
On the Solids pane:
button to create a new solid
OKbutton.
OKto create the output
Volume fraction,Pressure, andVelocity vectorcheck-boxes on theFluidsub-sub-pane
3.2.12. Run the project¶
Save project by clicking the
3.2.13. View results¶
Change frames with the
, and
buttons
section on the sidebar.
Meshpane, change theX Cellsto 80 and theY Cellsto 180On the
Outputpane,VTKsub-pane, change the write interval to0.01Save and run the project.
