Among the tutorials listed on the New Menu, only the tfm/silane_pyrolysis_2d case has UDFs and requires running with a custom solver to run correctly.
However, for some cases you may want to use a custom mfixsolver. For instance, when
solver. A custom solver is an mfixsolver
executable built in the project
directory, specific to that project. This includes projects with chemical
reactions, since those have UDFs.
Press the (Build) button to display the Build Dialog box. Select appropriate compilation options, then press the “Build Solver” button. It may take a few minutes to compile. See Build Dialog for further details about compilation options. The “Build Command” of the build dialog will show the equivalent command for Building Custom Interactive Solver.
After building the custom solver, run a simulation by pressing (Run) to display the Run Dialog. Select the mfixsolver file you have just built.
For example, the tfm/silane_pyrolysis_2d
default solver.
> ls
To build a custom solver for tfm/silane_pyrolysis_2d
> build_mfixsolver
...build output...
> ls *
The build_mfixsolver
command creates a wrapper script
mfixsolver
, that runs the case-specific MFiX solver (which is
installed in the lib
directory).
The build
will still run. However, leaving the build
directory will greatly
build_mfixsolver
again.
