4.6. Solids¶
The solids pane is used to set solids phases material properties. The “Materials” tab sets material properties shared by most models (TFM, DEM and PIC). Specific settings for each model are accessed through their respective tabs (TFM, DEM, or PIC).
4.6.1. Creating a solids phase¶
A new solids phase is created by clicking the add button, ,
at the top of the solids table. This will create a new entry
in the table. The table summarizes all defined solids phases
by listing the name, model, particle diameter and density.
A blank entry in the density means the particle density is
variable (it depends on its chemical composition).
- Name
The name used to refer to the solids phase in the GUI. By default, the solids phase is called “Solid” followed by its assigned phase number. The phase number is incremented every time the
button is pressed. The solids phase name may be renamed for convenience (optional). This name will appear in other panes or tabs when referring to the solids phase (say while setting initial or boundary conditions).
Model (read only)
4.6.2. Deleting a solids phase¶
A solids phase can be deleted by selecting it (click on its name in the
solids table) and clicking the remove button, ,
at the top of the solids table. If the solids phase is used in the
model with a non-zero solids fraction (say in an initial or
boundary condition), the deletion will need to be confirmed by the user.
If confirmed, the deleted solids volume fraction will be assigned
back to the fluid phase.
4.6.3. General solid model options¶
- Solve momentum equation (TFM only)
- Solve species equations
4.6.4. Solids phase material properties¶
Some material properties are only needed for a specific solid model or when the energy or species equation is solved.
- Diameter \((m)\)
- Density \((kg/m^3)\)
Constant:
A positive (non-zero) number must be provided.
The diameter may change due to chemical reactions.
Variable:
The density is computed from particle’s mass and volume.
The particle mass is function of the particle’s chemical composition.
A variable density can only be used if species equations are solved.
- Viscosity \((Pa\cdot{s})\) TFM only
Constant:
Continuum Solids stress Theory
User-Defined Function (UDF)
A custom equation of state must be provided in the usrproperties.f
A custom solver must be built.
- Molecular weight \(({kg}/{kmol})\)
Mixture
Requires species be used to defined the solid.
Requires species mass fractions be specified for the whole domain and all flow boundary conditions
- Specific heat \(({J}/{kg\cdot{K}})\)
Constant:
Mixture
Requires species be used to defined the fluid.
- Thermal conductivity \(({W}/{m\cdot{K}})\)
Constant:
A non-negative number must be provided.
Temperature-Dependent
Option available for TFM only.
Requires solids phase temperature be specified for the whole domain and all flow boundary conditions.
- Emissivity DEM only
- Parcel weight PIC only
4.6.5. Solids Model Species¶
Specie that comprise the solid phase are summarized in the species overview
table. New species are added by clicking the add button, , at the top
of the species table.
4.6.6. Advanced settings¶
- Disable close pack (TFM only)
- Enable added mass force (TFM only)
4.6.7. TFM Settings¶
- Packed bed void fraction
- Viscous stress model
The solids phase stress model. Options include the algebraic formulation or various kinetic theories requiring solving a partial differential equation for the granular energy:
Algebraic Formulation [DEFAULT]
Lun et al, 1984
Iddir & Arastoopour, 2005
Simonin, 1996 (requires k-ε turbulence enabled)
Cao & Ahmadi, 1995 (requires k-ε turbulence enabled)
Garzo and Dufty, 1999 (monodisperse system only)
Garzo, Tenneti, Subramaniam, Hrenya, 2012 (monodisperse system only)
Garzo, Hrenya and Dufty, 2007 - Requires at most two solids phases - Requires Wen-Yu or HYS drag model - Selection not available with added mass force
- Frictional stress model
Schaeffer model [DEFAULT]
Srivastava and Sundaresan
Only solids pressure
- Solids volume fraction at onset of friction
- Particle-particle restitution coefficient
- Interphase friction coefficient
- Angle of internal friction \((\deg)\) :
- Radial distribution function
Carnahan-Startling (only option for monodisperse systems)
Lebowitz (default for polydisperse system)
Mansoori (polydisperse system)
Modified Lebowitz (polydisperse system)
Modified Mansoori (polydisperse system)
- Stress blending
None [DEFAULT]
Hyperbolic Tangent
Sigmodial
- Segregation slope coefficient
- Max packing correlation
Constant [DEFAULT]
Yu & Standish
Fedors & Landel (only with two solids phases)
- Excluded volume in Boyle-Massoudi stress
4.6.8. DEM Settings¶
- Enable automatic particle generation
Initialize particle location and velocity based on information from Initial Condition regions. If this option is disabled and any initial condition uses a non-zero solids volume fraction, the user will be prompted to turn on this option. Disabling this option will read initial particle location and velocity from a user generated text file (particle_input.dat) that must be saved in the project directory.
- Data file particle count
The number of particles read from particle_input.dat file when the automatic particle generation is turned off. This number must be smaller or equal to the number of lines in the file.
- Particle Size Distribution (PSD)
A series of PSDs can be defined to be used in an initial condition region or a mass inlet boundary condition. A PSD represents the number of particles having a given size. It is currently a number-based (not volume-based) distribution. A new PSD is created by clicking the add button,
, and entering the PSD parameters. The PSD can follow a Normal or Log-normal distribution. There is an option to load a text file containing a custom PSD.
![PSD table](../_images/PSD_table.png)
Fig. 4.1 Particle Size Distribution table.¶
Initially, the table will be empty. Double click on one row to edit a PSD, Click on to remove a PSD
from the table.
Mean particle diameter
Standard deviation
Minimum diameter , used to clip the distribution and avoid extremely small particles
Maximum diameter , used to clip the distribution and avoid extremely large particles
![PSD definition](../_images/Hopper_dem_normal_psd_definition.png)
Fig. 4.2 Example of a Normal Particle Size Distribution definition.¶
![PSD custom file](../_images/PSD_custom_file.png)
Fig. 4.3 Example of a Custom file used to define a Particle Size Distribution.¶
Once the parameters are defined, the PSD can be plotted by clicling the ‘Plot distribution’ button.
![PSD plot](../_images/Hopper_dem_normal_psd_plot.png)
Fig. 4.4 Plotting a Particle Size Distribution.¶
- Integration method
Euler [DEFAULT]
Adams-Bashforth
- Collision model
Linear Spring Dashpot (LSD)
Hertzian
- Coupling method
One-way coupled
Fully coupled
- Interpolation
No interpolation
field-to-particle and particle-to-field
field-to-particle only
particle-to-field only
- Scheme
The interpolation scheme:
None (centroid method)
Garg, 2012 (interpolation width is dictated by grid spacing)
Square DPVM (Divided Particle Volume Method), requires an interpolation width.
- Width \((m)\)
- Enable mean field diffusion
- Width \((m)\)
The diffusion length scale.
- Enable explicit coupling of interphase quantities
- Friction coefficient
- Normal spring constant \(({N}/{m})\)
- Spring tan/norm ratio
- Damping tan/norm ratio
- Young’s modulus \((Pa)\)
- Poisson’s ratio
- Restitution coefficients (normal)
- Restitution coefficients (tangential)
- Cohesion model
- Hamaker constant \((J)\)
- Outer cutoff \((m)\)
- Inner cutoff
- Asperities
- Minimum fluid volume fraction
- Neighbor search method
Grid-based
N-Square
- Max steps between neighbor search
- Factor defining particle neighborhood
- Distance/diameter triggering search
- Search grid partition
- Enable user scalar tracking
- Minimum conduction distance \((m)\)
- Fluid lens proportionality constant
- Young’s modulus used to correct DEM conduction \((Pa)\)
- Poisson’s ratio used to correct DEM conduction
4.6.9. PIC Settings¶
Several of the PIC settings refer to the PIC solids stress model, which influences parcel motion:
\(\tau_p={P_p \epsilon_p^\gamma}/{\max[\epsilon_{cp} - \epsilon_p , \delta(1-\epsilon_p)]}\)
- Void fraction at close pack
The void fraction \((\epsilon_{cp})\) at maximum packing.
- Volume fraction exponential scale factor
The empirical exponent \((\gamma)\) on solids fraction in the solids stress model. Typical values are between 2.0 to 5.0.
- Pressure linear scale factor \((Pa)\)
The empirical pressure \((P_p)\) constant in the solids stress model. Typical values are 10 to 1000 Pa.
- Empirical dampening factor
- Non-singularity constant
The constant \((\delta)\) to prevent division by zero in solids stress model. Typical value is 1.0E-8.
- Wall normal restitution coefficient
- Wall tangential restitution coefficient
- Solids slip velocity scale factor
