Among the tutorials listed on the New Menu, only the tfm/silane_pyrolysis_2d case has UDFs and requires running with a custom solver to run correctly.
However, for some cases you may want to use a custom mfixsolver. For instance, when
directory, specific to that project. This includes projects with chemical
reactions, since those have UDFs.
Press the (Build) button to display the Build Dialog box. Select
default solver.
> ls
> build_mfixsolver
...build output...
> ls *
mfixsolver, that runs the case-specific MFiX solver (which is
installed in the lib directory).
build_mfixsolver again.
