5.3. Build from Source (for Developers)¶
5.3.1. Obtaining MFiX source¶
> tar xf mfix-22.3.1.tar.gz
> cd mfix-22.3.1
> pwd
/home/user/mfix-22.3.1
Folder |
model |
post_mfix |
Source code for the post-processing tool post_mfix |
queue_templates |
tutorials |
tests |
legacy_tutorials |
legacy_tests |
The source code is also available from the GUI, from the “Editor” tab. Files are located in the “MFiX source” file explorer. Selecting a file will open it in the editor. Users wishing to modify the source code should copy a file to the project directory. This is accomplished automatically by clicking “Copy” when prompted “Copy to project directory for editing?”
5.3.3. Building Solver from Source¶
You can build the Batch Solver from source, without the MFiX conda package installed. This is how MFiX was built in version 2016 and earlier.
For prerequisites, see Linux Build Dependencies or Mac Build Dependencies.
build issues to the forum.
5.3.3.1. Configuring¶
> pwd
/home/user/mfix-22.3.1 # actual working directory will vary
> mkdir release-build
> cd release-build
> cmake .. -DCMAKE_BUILD_TYPE=RelWithDebInfo # .. is the relative path to the top-level MFiX source directory
> cmake .. # same thing (RelWithDebInfo is the default CMAKE_BUILD_TYPE)
> mkdir debug-build
> cd debug-build
> cmake .. -DCMAKE_BUILD_TYPE=Debug
> mkdir release-build
> cd release-build
> cmake .. -DCMAKE_BUILD_TYPE=RelWithDebInfo -DENABLE_MPI=1
> mkdir debug-build
> cd debug-build
> cmake .. -DCMAKE_BUILD_TYPE=Debug -DENABLE_MPI=1
> cmake .. -DCMAKE_Fortran_COMPILER=ifort # for example
> cmake .. -DCMAKE_Fortran_FLAGS="-O0 -g -Wall -fcheck=all" # for example
> cmake .. -ENABLE_OpenMP=1
> cmake .. -ENABLE_OpenMP=1 -DCMAKE_Fortran_COMPILER=ifort -DCMAKE_Fortran_FLAGS="-O0 -g -Wall -fcheck=all"
> cmake .. -DENABLE_MPI=0 -DCMAKE_Fortran_COMPILER=gfortran -DCMAKE_Fortran_FLAGS="-O2 -g"
> cmake .. -DENABLE_MPI=0 -DCMAKE_Fortran_COMPILER=gfortran -DCMAKE_Fortran_FLAGS="-march=native -O3"
> cmake .. -DENABLE_MPI=1 -DMPI_Fortran_COMPILER=mpifort -DCMAKE_Fortran_FLAGS="-O2 -g"
> cmake .. -DENABLE_MPI=0 -DCMAKE_Fortran_COMPILER=gfortran -DCMAKE_Fortran_FLAGS="-O0 -fcheck=all -g"
> cmake .. -DENABLE_MPI=1 -DMPI_Fortran_COMPILER=mpifort -DCMAKE_Fortran_FLAGS="-O0 -fcheck=all -g"
compiler you intend to use.
with different options.
5.3.3.2. Building¶
type man make at the prompt.
> make
> make -j # for parallel build jobs
> make VERBOSE=1 # to view the full command lines used for compiling and linking
5.3.4. Building Conda package¶
To build the conda package of MFiX, you will need to install the build dependencies for your platform. Please see Linux Build Dependencies or Mac Build Dependencies.
Install conda-build:
> conda install conda-build
The conda package recipes are under conda/. Refer to the
conda-build documentation for
details.
