6.3. Running Custom Interactive Solver¶
First build a custom solver.
6.3.1. Running Custom Solver From GUI¶
6.3.2. Running Custom Solver From Command Line¶
As an example, the tfm/silane_pyrolysis_2d
default solver.
After building the solver, on a Linux or Mac system, run the custom solver with the command:
~/projectdir> ./mfixsolver -f SP2D.mfx
Use ./
in front of mfixsolver to use the solver in the project directory, not the default solver in your PATH
On Windows, run the custom solver in the project directory with:
C:\projectdir > mfixsolver -f SP2D.mfx
