12. Frequently Asked Questions¶
This document explains how to perform common tasks with MFiX.
12.1. How do I ask question, or send feedback?¶
Please allow sufficient time (say 2 to 3 business days) for MFiX developers and users to reply before posting unanswered questions again.
MFiX version.
Operating system.
*.mfx
,*.stl
,*.f
,particle_input.dat
etc.):Create a zip file from main menu> submit bug report.
Run the solver in debug mode?
12.2. Graphical User Interface (GUI)¶
12.2.1. How do I change the look & feel of the GUI?¶
12.2.2. MFiX (VTK) crashes on RHEL/CentOS 7 with the following error message:¶
If this solves the issue for your system, you can add export
to your shell profile.
12.2.3. How do I build the custom solver in parallel?¶
parallel” check box. This will pass the -j
option to the make
command.
12.3. Pausing and restarting the solver¶
12.3.1. Play/Pause/Reinit¶
(save) button
and press the
(start) button.
12.3.2. Restart a simulation from current time¶
and press the
12.3.3. Restart a simulation from the beginning¶
First press the
(save) button, and press the
(start) button.
12.4. What system of units does MFiX use?¶
MFiX SI unit |
length, position |
meter \((m)\) |
mass |
kilogram \((kg)\) |
time |
second \((s)\) |
thermal temperature |
Kelvin \((K)\) |
energy† |
Joule \((J)\) |
amount of substance‡ |
kilomole \((kmol)\) |
force |
Newton (\(N = kg·m·s^{-2}\)) |
Pascal (\(Pa = N·m^{-2}\)) |
dynamic viscosity |
\(Pa·s\) |
kinematic viscosity |
\(m^2·s^{-1}\) |
gas constant |
\(J·K^{-1}·kmol^{-1}\) |
enthalpy |
\(J\) |
specific heat |
\(J·kg^{-1}·K^{-1}\) |
thermal conductivity |
\(J·m^{-1}·K^{-1}·s\) |
‡ The SI unit for the amount of a substance is the mole (mol). MFiX uses the kilomole (kmole). These units are needed when specifying reaction rates:
amount per time per volume for Eulerian model reactions (kmole.s^{-1}.m^3)
amount per time for Lagrangian model reactions (kmole.s^{-1})
12.5. What do I do if a run does not converge?¶
12.5.1. Initial non-convergence¶
Holding the time step constant (DT_FAC=1
) and ignoring the stalling of
iterations (DETECT_STALL=.FALSE.
) may help in overcoming initial nonconvergence.
reducing UR_FAC(2)
below the default value of 0.5.
Convergence is often difficult with higher order discretization methods. First order upwinding may be used to overcome initial transients and then the higher order method may be turned on. Also, higher-order methods such as van Leer and minmod give faster convergence than methods such as superbee and ULTRA-QUICK.
12.5.2. Non-convergence due to bad cut-cell mesh¶
Fig. 12.1 Removing small cut-cells¶
12.6. Discrete Element Model (DEM)¶
12.6.1. How to provide initial particle positions in particle_input.dat file?¶
We can read the initial particle data from a text file, called particle_input.dat
Below is an example of a particle_input.dat
file (the line number is shown on the left and it
not part of the data itself):
Lines 32-34: Data header
1 Version 2.0
3 Instructions:
19 Dimension: 3
20 Particles: 35361
25 Phase_ID: F 1
26 Diameter: T
27 Density: F 2500.0
28 Velocity: F 0.0 0.0 0.0
The particle_input.dat
file can be edited in any text editor, including the GUI editor, and be
Below is an example of a 2D particle_input.dat
(only 4 particles shown):
Below is an example of a 3D particle_input.dat
12.6.2. How to avoid particles going through solid walls in DEM simulations?¶
Fig. 12.2 Left: Soft particles (kn=kn_w=100 N/m) going through the cyclone wall. Right: Harder particles (kn=kn_w=1000 N/m) bouncing off the wall.¶
Fig. 12.3 Spring stiffness settings in the GUI¶
12.7. SuperQuadric Particle Model (SQP)¶
12.7.1. How to specify the particle shape?¶
Fig. 12.4 Superquadric designer¶
Fig. 12.5 Favorable exponent map¶
Examples:
a |
b |
c |
m |
n |
shape |
view |
0.003 |
0.003 |
0.003 |
2.0 |
2.0 |
sphere |
0.003 |
0.001 |
0.006 |
2.0 |
2.0 |
ellipsoid |
0.003 |
0.001 |
0.006 |
8.0 |
8.0 |
cuboid |
0.003 |
0.003 |
0.006 |
2.0 |
8.0 |
cylinder |
12.7.2. Recommended settings¶
12.8. Meshing¶
12.8.1. How to verify/flip STL file facet normals?¶
Fig. 12.6 Displaying STL normals, internal flow¶
Fig. 12.7 Flipping STL normals to model an external flow¶
12.8.2. How to manually specify a grid partition for DMP runs?¶
To specify this decomposition, the following gridmap.dat
needs to be saved in the project directory:
0 10
1 10
0 10
1 10
2 10
3 70
0 10
1 10
Below is the entire gridmap.dat
file:
0 10
1 10
0 10
1 10
2 10
3 70
0 10
1 10
Fig. 12.8 Default partition (uniform distribution)¶
Fig. 12.9 Adjusted partition in vertical direction (specified with gridmap.dat)¶
12.9. Particle in Cell (PIC)¶
12.9.1. How To Choose a Good Statistical Weight for PIC Runs?¶
12.9.2. PIC statistical weight example¶
12.9.3. Meshing Basics for PIC Runs¶
12.9.4. Choosing Primary PIC Parameters¶
12.9.5. Choosing Secondary PIC parameters¶
12.9.6. Why can’t I define parcels per cell instead of particles per parcel?¶
12.9.7. What is a good number (or range) for the number of parcels per cells?¶
12.9.8. What solids model parameter values work best for the PIC model when running 2 densities that are roughly 10x different in magnitude?¶
