3.9. DEM initial conditions
3.9.1. Open the 3d hopper tutorial
  • On the main menu, select New project
  • Double click on the “3D DEM granular flow hopper” tutorial and specify the project location.
  • Run the project as is to get familiar with it.
3.9.2. Change the initial condition configuration
  • On the Initial conditions pane, select the “Initial solids” region.
  • Change the Solid 1 volume fraction to 0.4. Note that we are using an hexagonal lattice.
  • On the Run pane, change Stop time to 0.001. We are only interested to look at the initial conditions.
  • Run the simulation. Visualize the particles and take a look at the output in the console and verify that seeding was successful:
Phase  1: Number of particles to seed =        18236
| IC Region:   2                                                    |
| Phase |   Input   |   Input   | Number of |    EPs    |   Solid   |
|   ID  | Specified |   Value   | Particles |           |   mass    |
|    1  |   EP_S    |  4.00E-01 |     18236 |  4.00E-01 |  1.91E+02 |
Phase  1: Successful seeding
  • Change the lattice configuration to “Cubic”.
  • Run the simulation. Visualize the particles and take a look at the output in the console and notice that with the cubic lattice, we are not able to reach the specified volume fraction of 0.4.
| IC Region:   2                                                    |
|    1  |   EP_S    |  4.00E-01 |     15693 |  3.44E-01 |  1.64E+02 |
Phase  1: Unsuccessful seeding
  • In the drop down menu, select “Inventory” and enter 100.0.
  • Run the simulation and verify seeding was successful.
  • In the drop down menu, select “Particle count” and enter 10000.
  • Change the Solid 1 volume fraction to 0.1.
  • Change the spacing to 0.5, run the simulation and observe how particles are more spaced out.
  • Change the random factor to 1.0, run the simulation and observe how particles have randomly shifted from their lattice positions.
3.9.3. Particle size distribution
  • Make sure the Solid 1 volume fraction is 0.1, and the lattice is Hexa.
  • Change the spacing back to 0.05, and the random factor back to 1.0.
  • In the Solids>DEM pane, Click the Add button in the Particle size distribution table (the table is initially empty if no psd have been defined yet):
PSD table
Fig. 3.1 PSD table.
  • Define a Normal psd:
    • Name: Normal (mean = 0.01 m) (use a descriptive name).
    • Distribution type: Normal
    • Mean: 0.01
    • Standard deviation: 0.001
    • Minimum: 0.005
    • Maximum: 0.015
    • Plot from 0 to 0.020
Normal PSD definition
Fig. 3.2 Normal PSD definition.
  • Plot the psd by clicking on Plot distribution. Verify the plot corresponds to the parameters.
Plotting the Normal PSD definition
Fig. 3.3 Normal PSD plot.
  • Click OK.
  • Go to the Initial condition pane, go to the drop down menu under ‘Particle size distribution’ and select the psd we just defined, Normal (mean = 0.01 m).
  • Run the simulation and visualize the particles.
1st line: Number of points, number of distribution (this must be set to one currently).
2nd line: PDF (probability density function) of CDF (Cumulative distribution function).
3rd line: Header.
4th line and below: The data itself. First column is the diameter, second column is either the PDF or CDF value.
PSD custom file
Fig. 3.4 Example of a Custom file used to define a Particle Size Distribution.
  • In the Solids>DEM pane, Click the Add button in the Particle size distribution table, and define a custom psd:
  • Name: Bimodal psd (use a descriptive name).
  • Distribution type: Custom
  • Select file: Choose bimodal_psd.txt in the project directory.
  • Click Plot distribution.
Custom PSD
Fig. 3.5 Custom PSD.
  • Run the simulation and visualize particles.
  • Notice that we are not able to seed particles with the requested solids volume fraction of 0.1. This is because the lattice spacing is based on the largest diameter in the psd.
  • Change the spacing to 0.02, run the simulation and verify that we get a volume fraction of 0.1 (or near 0.1).
  • While the simulation is running, we can visualize a histogram showing the particle size distribution. Open a new visualization viewport by clicking on the Add sign on the right-most tab and select the histogram view. This will setup a histogram plot. Users can change the file to view, the variable, number of bins and style (lines or bars). To adjust the scale, right-click on the view and enter the axis limits or have them be automatically updated based on data.
Opening histogram.
Fig. 3.6 Opening a histogram view.
Visualizing particle diameter histogram.
Fig. 3.7 Visualizing particle diameter histogram.
3.9.4. Reading initial particle data from a text file
We can read the initial particle data from a text file, called particle_input.dat. The format of this file has changed in the 20.3 release. The old file version can still be used but it is recommended to use the latest format.
Below is an example of a particle_input.dat file (the line number is shown on the left and it not part of the data itself):
  • Line 1 : File version. Do not change this line.
  • Lines 2-18 : Instructions to use the file.
  • Line 19 : This is a 3D geometry. The first 3 columns in the data section will be x,y,z.
  • Line 20 : We will read data for 35361 particles.
  • Line 24 : We always read coordinates in the first 2 or 3 columns (do not change)
  • Line 25 : We do not read particle’s phase ID for each particle. It is assigned a constant value: 1
  • Line 26 : We will read the particle’s diameter in the next column (column#4).
  • Line 27 : We do not read particle’s density. It is assigned a constant value: 2500.0 kg/m^3
  • Line 25 : We do not read particle’s velocity. It is assigned a constant value: (u,v,w) = (0.0,0.0,0.0) m/s
  • Lines 29-30: This is a cold, non reacting case, we do not read Temperature or species.
  • Line 31 : We do not have user scalars, so we do not read them.
  • Lines 32-34: Data header
1 Version 2.0
3 Instructions:
19 Dimension:    3
20 Particles:    35361
22 Variable      Read(T/F)     Default value (when Read=F)
24 Coordinates:     T          Must always be T
25 Phase_ID:        F          1
26 Diameter:        T
27 Density:         F          2500.0
28 Velocity:        F          0.0 0.0 0.0
29 Temperature:     F          (Ignored if energy eq. is not solved)
30 Species:         F          (Ignored if species eq. are not solved)
31 User_Scalar:     F          (Ignored if no user scalars are defined)
33     X (m)           Y (m)           Z (m)       Diameter (m)
35 -5.07749E-02    -7.98147E-01    -2.00612E-01    9.71052E-03
36 -4.86164E-02    -8.16202E-01    -2.25035E-01    8.34185E-03
37 -3.16460E-02    -8.13702E-01    -2.19164E-01    1.09747E-02
38 -3.32833E-02    -8.25178E-01    -2.19393E-01    9.67983E-03
39 -2.48844E-02    -8.30159E-01    -2.16423E-01    9.84182E-03
40 -8.57591E-03    -8.38121E-01    -2.08773E-01    9.92759E-03
41 -2.75312E-03    -8.32665E-01    -2.00770E-01    1.07560E-02
42 1.57276E-02     -8.37839E-01    -2.08196E-01    1.04387E-02
43 1.96605E-02     -8.31447E-01    -2.15105E-01    9.97808E-03
44 2.71083E-02     -8.26450E-01    -2.19492E-01    9.99619E-03
45 3.55440E-02     -8.28885E-01    -2.15687E-01    9.15771E-03
46 4.45244E-02     -8.28239E-01    -2.11771E-01    1.05089E-02
47 4.70488E-02     -8.22092E-01    -2.19129E-01    9.33350E-03
  • In the Solids>DEM pane, uncheck Enable automatic particle generation, and enter a data file particle count of 35361. An entry is required to maintain compatibility with the old format, but the value on line 20 of the version 2.0 file will actually be used.
  • In the Initial condition pane, delete the Initial solids initial condition.
  • In the Run pane, set Stop time to 1.0 seconds.
  • Run the simulation. You should see the initial configuration shown below:
Example of a DEM initial condition using particle_input.dat version 2.0.
Fig. 3.8 Example of a DEM initial condition using particle_input.dat version 2.0.
