3.1. First tutorial¶
3.1.1. Starting the MFiX GUI¶
On Windows, open the Anaconda Prompt and activate the mfix environment
# Windows
conda activate mfix-23.1
(mfix-23.1) C:\> mfix
# Linux or Mac
(mfix-23.1) > mfix
3.1.2. Creating a project¶
(New)
Icon |
Single phase Model |
Two-fluid Model (TFM) |
Hybrid Model (TFM + DEM) |
Chemistry |
(single phase), and
(chemistry) icons
Double-click on
Click Ok
3.1.3. Running the solver¶
[default]/mfixsolver
3.1.4. View results¶
3.1.5. Pausing/unpausing¶
3.1.6. Stopping/resuming¶
Clicking the
