3.6. Three-dimensional DEM hopper¶
5 cm diameter hopper |
10 x 25 x 10 |
0.003 m |
NA |
NA |
3.6.1. Create a new project¶
Model
drop-down menuCheck the
Disable Fluid Solver (Pure Granular Flow)
checkbox.
3.6.3. Enter the geometry¶
3.6.4. Enter the mesh¶
pane, Background
25
for the y cell valueEnter
for the z cell value
pane, Mesher
0.0
in theFacet Angle Tolerance
Select the Regions
name
such as “walls”Check the
Select facets (STL)
checkbox to turn the region into a STL region. The facets of the hopper should now be selected.
Y Min
domain extent value on the geometry pane by a small amount so that those facets fall outside the simulation domain (for example, change the value to-0.0974
).Change the
Y From
region extent value on the regions pane for this STL region by a small amount so that those facets fall outside the region (for example, change the value toymin+0.0001
)Or, use the
Filter facets based on normals
option on the region pane.
the Y
direction by:
box
from theSelection method
drop-down.Uncheck
Slice facets
.Check the
checkboxEnter a vector pointed in the positive
Y
direction by entering0
,1
, and0
in the x, y, z fields, respectivelyCheck the
Include equilibrant vector
to include facets with normals in the opposite direction of the vector (-x, -y, -z)Enter an angle of
in theangle
field to include facets with normals within 10 degrees of the filter vectorCheck the
Invert Selection
check box to de-select facets that fall along the filter vector and select all the other facets
3.6.6. Create a solid¶
pane
field (“solids”)Keep the model as “Discrete Element Model (MFiX-DEM)”)
0.003
2500
kg/m2 in theDensity
In the DEM
sub-pane, check Enable automatic particle generation
checkbox
pane
the hopper by:
Select region
drop-down menuSelect the “walls” region and click
3.6.9. Select output options¶
Output
paneOn the
checkbox
sub-paneOn the “select region” dialog, select “particle data” from the
output type
drop-down menuSelect the “Background IC” region from the list to save particle data over the entire domain
to0.01
secondsSelect the
Diameter
andTranslational velocity
checkboxes
Change
Stop time
to2.0
secondsChange
to1e-3
secondsChange
to1e-2
seconds
3.6.11. Run the project¶
3.6.12. View results¶
