3.10. Procedural geometry¶
3.10.1. Create a new project¶
3.10.2. Create the geometry¶
First, create a cylinder:
Go to the Geometry
pane and click the button to add geometry:
Radius =
0.05
m, Height =0.225
m, Resolution =20
Start angle=
deg, end angle =360
deg, resolution =32
Check the
Bottom cap
andTop cap
check boxes and set the resolution to5
for both caps.
Next, create a bend:
Go to the Geometry
Choose
Procedural > Bend
as the geometry input (named “bend”).Enter the bend’s parameters:
Front section: Radius =
0.02
m, Length =0.05
m, Resolution =10
Back section: Radius =
0.05
m, Length =0.25
m, Resolution =20
Bend section: Major radius =
0.075
m, Minor radius =0.02
m, Start angle=0
deg, end angle =90
deg, resolution =16
Circumference: Start angle=
deg, end angle =360
deg, resolution =16
Check the
Bottom cap
andTop cap
check boxes and set the resolution to3
for both caps. Leave Offset =0
Next, create another bend:
Go to the Geometry
Choose
Procedural > Bend
as the geometry input (namedbend1
0.02
m, Length =0.1
m, Resolution =10
0.02
m, Length =0.1
m, Resolution =10
0.05
m, Start angle=0
deg, end angle =90
deg, resolution =10
deg, end angle =360
deg, resolution =16
Check the
Bottom cap
andTop cap
edges
, opacity to 1.0, check theShow normals
box, set theScale
to 0.01, setcount
to 10,000 (to show all normals).
union1
geometry,Add a filter:
flip normals
. Now the vectors point towards the fluid region. The tips of the arrows are not visible, but we can see the origin (shown as a dot at the center of each face).
In
Domain extent
, enter the following:X-direction: Min =
-0.055
m, Max =0.055
m.Y-direction: Min =
0.01
m, Max =0.35
m.Z-direction: Min =
-0.1
m, Max =0.18
m.
Go to the Regions
There is already a
Background IC
that is predefined in the Blank template. We can ignore it for now.Click the
Mass inflow
in the Boundary type drop down menu.Enter a name for the region in the Name field (“top inlet”).
Mass inflow
in the Boundary type drop down menu.Enter a name for the region in the Name field (“bottom inlet”).
Pressure outflow
in theBoundary type
drop down menu.Enter a name for the region in the Name field (“outlet”).
No-slip wall
in theBoundary type
field (“wall”).Change the region color to green.
Select facets (STL)
andflip_normals
, useall
for the selection method. You should see that there are 4003 facets selected.
Leave the
Boundary type
asNone
field (“init bed”).Change the region color to black.
Set the Y-extent form
ymin
to0.15
m.
3.10.5. Setup the mesh¶
Go to the Mesh
pane, Background
15
for the x cell value.Enter
35
for the y cell value.Enter
for the z cell value.
Go to the Mesh
pane, Mesher
0.0
deg. (The geometry unions have created elongated triangles we need to keep).Click
Generate
.Look at the console output to verify the mesh generation completed successfully.
Color by
tobc_id
, - setStyle
toedges
and opacity to1.0
.The Boundary_Mesh should look like a closed surface with colors matching the boundary conditions regions.
After inspection, the mesh is deemed acceptable and we can move to setting up the simulation (Solver mode). Click Accept
. This will unlock the Modeler tab.
3.10.6. Model settings¶
Model
field.Select “Discrete Element Model (MFiX-DEM)” in the
drop-down menu.Keep all other settings at their default values.
3.10.7. Regions settings¶
3.10.8. Fluid settings¶
Change Density to
Ideal gas law
3.10.9. Solids settings¶
pane, Materials
0.005
field.Enter the particle density of
2700
kg/m3 in theDensity
field.Select the
Solids
pane,DEM
sub-pane.Check the
checkbox.Keep all other settings at their default values.
3.10.10. Initial conditions settings¶
3.10.11. Boundary conditions settings¶
top inlet
region. In theSolids 1
tab, enter0.2
for the volume fraction and-0.2
for the Y-axial velocity.Select the
bottom inlet
region. Stay on theFluid
tab, enter4.0
for the Y-axial velocity.The outlet Boundary Conditions is already set to atmospheric pressure. No changes are needed.
3.10.12. Numerics settings¶
On the Numerics
0.0
and the fluid pressure correction scale factor to1.0
On the Preconditioner tab, set the preconditioner to
None
for all equations.
3.10.13. Output settings¶
checkbox.Select the
sub-pane.Select “Particle Data” from the ‘Output type’ drop-down menu.
to create the output.Enter a base name for the
*.vtu
files in theFilename base
field (“Particles”).Change the
to0.01
seconds.Select the
Diameter
andTranslational Velocity
checkboxes.
3.10.14. Run settings¶
Set
Stop time
to1.0
.Set
to0.001
.Set
to0.01
3.10.15. Run the simulation¶
3.10.16. View results¶
