4.11. Monitors¶
Data (such as volume fraction, pressure, velocity, etc.) for a given Region Selection is written to a CSV file while the solver is running.
![../_images/monitors.png](../_images/monitors.png)
Fig. 4.10 Monitor pane¶
4.11.1. Region Selection¶
To define a monitor, there must be a region already defined in the Regions
Pane. Click the button at the top, which will open a popup
window for selecting the region. A Monitor region is a single point, plane, or
volume. Multiple regions cannot be combined for a monitor, and STL regions
cannot be used for monitors.
4.11.2. Monitor Output¶
- Filename
The monitor output file will have a default name based on the name of the monitor’s region. You can edit the filename of a monitor by selecting the monitor from the list of monitors and changing “Filename base”. The monitor data will be output to the Filename base with the extension
.csv
.The monitor output file is in Comma Separated Value (CSV) format. The first line of the file provides header information. For example, running the Silane Pyrolysis tutorial (SP2D) will generate a file
PROBE_SPECIES.csv
:# # Run type: NEW # "Time","x_g(1)","x_g(2)","x_g(3)","x_g(4)","x_g(5)","x_s(1,1)","x_s(1,2)" 0.0000000 , 0.0000000 , 0.0000000 , 0.0000000 , 0.0000000 , 1.0000000 , 0.0000000 , 1.0000000
- Write Interval
4.11.3. Eulerian Monitors¶
Volume fraction (of all fluid species)
Fluid Pressure
Fluid Velocity
Fluid Temperature
Turbulent Kinetic Energy
Turbulent Dissipation
Volume fraction of each individual fluid species
Velocity of this solid phase
Bulk Density of this solid phase
Temperature of this solid phase
Granular Temperature of this solid phase
Pressure (total for all solid species for this solid phase)
Mass fraction of each individual species of this solid phase
Symbol |
\(\phi_{ijk}\) |
Variable value at indexed cell |
\(\varepsilon_{ijk}\) |
Phase volume fraction at indexed cell |
\(\rho_{jk}\) |
Phase density at indexed cell |
\(\vec{v}_{jk}\) |
Phase velocity at indexed cell |
\(A_{ijk}\) |
Cross-sectional area of cell |
\(V_{ijk}\) |
Volume of indexed cell |
4.11.3.1. Point Region¶
- Value
\[\phi_{ijk}\]
4.11.3.2. Area or Volume Region¶
- Sum
\[\sum_{ijk}\phi_{ijk}\]- Min
\[\min_{ijk} \phi_{ijk}\]- Max
\[\max_{ijk} \phi_{ijk}\]- Average
Average value of the field quantity in the selected region where \(N\) is the total number of observations (cells) in the selected region.
\[\phi_0 = \frac{\sum_{ijk} \phi_{ijk}}{N}\]- Standard Deviation
The standard deviation of the field quantity in the selected region where \(\phi_0\) is the average of the variable in the selected region.
\[\sigma_{\phi} = \sqrt{\frac{ \sum_{ijk} (\phi_{ijk}-\phi_{0})^2 }{N}}\]
4.11.3.3. Surface Integrals¶
- Area
\[\int dA = \sum_{ijk} \lvert A_{ijk} \rvert\]- Area-Weighted Average
\[\frac{\int\phi dA}{A} = \frac{\sum_{ijk}{\phi_{ijk} \lvert A_{ijk} \rvert}}{\sum_{ijk}{\lvert A_{ijk} \rvert}}\]- Flow Rate
The flow rate of a field variable through a surface is computed by summing the product of the phase volume fraction, density, the selected field variable, phase velocity normal to the facet \(v_n\), and the facet area.
\[\int\varepsilon\rho\phi{v_n}dA = \sum_{ijk}\varepsilon_{ijk}\rho_{ijk}\phi_{ijk} {v}_{n,ijk} \lvert A_{ijk} \rvert\]- Mass Flow Rate
The mass flow rate through a surface is computed by summing the product of the phase volume fraction, density, phase velocity normal to the facet \(v_n\), and the facet area.
\[\int\varepsilon\rho{v_n} dA = \sum_{ijk}\varepsilon_{ijk}\rho_{ijk}{v}_{n,ijk} \lvert A_{ijk} \rvert\]- Mass-Weighted Average
\[\frac{\int\varepsilon\rho\phi\lvert{v_n}dA\rvert}{\int\varepsilon\rho\lvert{v_n}dA\rvert} = \frac{\sum_{ijk}\varepsilon_{ijk}\rho_{ijk}\phi_{ijk}\lvert {v}_{n,ijk} A_{ijk} \rvert}{\sum_{ijk}\varepsilon_{ijk}\rho_{ijk} \lvert {v}_{n,ijk} A_{ijk} \rvert}\]- Volume Flow Rate
The volume flow rate through a surface is computed by summing the product of the phase volume fraction, phase velocity normal to the facet \(v_n\), and the facet area.
\[\int\varepsilon{v_n}dA = \sum_{ijk}\varepsilon_{ijk}{v}_{n,ijk} \lvert A_{ijk} \rvert\]
4.11.3.4. Volume Integrals¶
- Volume
\[\int dV = \sum_{ijk}{ \lvert V_{ijk}} \rvert\]- Volume Integral
\[\int \phi dV = \sum_{ijk}{\phi_{ijk} \lvert V_{ijk}} \rvert\]- Volume-Weighted Average
\[\frac{\int\phi dV}{V} = \frac{\sum_{ijk}{\phi_{ijk} \lvert V_{ijk} \rvert}}{\sum_{ijk}{\lvert V_{ijk} \rvert}}\]- Mass-Weighted Integral
\[\int \varepsilon\rho\phi dV = \sum_{ijk}\varepsilon_{ijk}\rho_{ijk}\phi_{ijk} \lvert V_{ijk}\rvert\]- Mass-Weighted Average
\[\frac{\int\phi\rho\varepsilon dV}{\int\rho\varepsilon dV} = \frac{\sum_{ijk}\varepsilon_{ijk}\rho_{ijk}\phi_{ijk} \lvert V_{ijk}\rvert}{\sum_{ijk}\varepsilon_{ijk}\rho_{ijk} \lvert V_{ijk}\rvert}\]
4.11.4. Lagrangian Monitors¶
Radius
Mass
Volume
Density
Translational velocity components
Rotational velocity components (DEM only)
Temperature
DES user variable (DES_USR_VAR)
Symbol |
\(\phi_p\) |
Variable value of the indexed particle |
\(m_p\) |
Mass of the indexed particle |
\(V_p\) |
Volume of the indexed particle |
\(\mathcal{w}_p\) |
Statistical weight of the indexed particle 1 |
- 1
The statistical weight is one for DEM simulations.
4.11.4.1. General particle properties¶
- Sum
The sum of particle property, \(\phi_p\) in the selected region is calculated using the following expression.
\[\sum_p w_p \phi_p\]- Min
The minimum value of particle property \(phi_p\) is the selected region is obtained using the following expression.
\[\min_p \phi_p\]- Max
The maximum value of particle property \(phi_p\) is the selected region is obtained using the following expression.
\[\max_p \phi_p\]
4.11.4.2. Averaged particle properties¶
- Average
The average value of particle property, \(\phi_p\) in the selected region is calculated using the following expression. For DEM simulations, the statistical weight of a particle, \(w_p\), is one such that the sum of the weights is the total number of observations in the selected region.
\[\bar{\phi} = \frac{\sum_p w_p \phi_p}{\sum_p w_p}\]- Standard Deviation
The standard deviation of particle property, \(phi_p\) in the selected region is calculated using the following expression. \(\bar{\phi}\) is the averaged variable in the selected region.
\[\sigma_{\phi} = \sqrt{\frac{ \sum_p w_p (\phi_p-\bar{\phi})^2 }{\sum_p w_p}}\]- Mass-weighted average
Mass-weighted average value of particle property, \(\phi_p\) in the selected region is calculated using the following expression.
\[\bar{\phi}_m = \frac{\sum_{p} w_p m_p \phi_p}{\sum_p w_p m_p }\]- Volume-weighted average
Volume-weighted average value of particle property, \(\phi_p\) in the selected region is calculated using the following expression.
\[\bar{\phi}_v = \frac{\sum_{p} w_p V_p \phi_p}{\sum_p w_p V_p}\]
4.11.4.3. Flow rates¶
Flow rate monitors for Lagrangian particles (DEM/PIC) are only valid for area (plane) regions. The set of particles crossing the flow plane, \(\Gamma\) is approximated using the height of the plane, \(h\), the position of the particle, \(x_p\), and the particle velocity normal to the plane, \(v_p\) such that
\[(v_p)(\frac{x_p - h}{\Delta t}) > 0\]
and
\[\left|v_p\right| \geq \left| \frac{x_p - h}{\Delta t} \right|\]
- Flow rate
The net flow rate of a general particle property \(\phi_p\) is computed by summing the properties of the set of particles projected to have crossed the flow plane, \(\Gamma\).
\[\sum_{p \in \Gamma} w_p \phi_p \frac{v_p}{\left| v_p \right|}\]- Mass-weighted flow rate
The net mass-weighted flow rate is the sum of the general particle property \(\phi_p\) multiplied by the particle mass, \(m_p\) of the set of particles projected to have crossed the flow plane, \(\Gamma\).
\[\sum_{p \in \Gamma} w_p m_p \phi_p \frac{v_p}{\left| v_p \right|}\]- Volume-weighted flow rate
The net volume-weighted flow rate is the sum of the general particle property \(\phi_p\) multiplied by the particle volume, \(V_p\) of the set of particles projected to have crossed the flow plane, \(\Gamma\).
\[\sum_{p \in \Gamma}\phi_p w_p V_p \frac{v_p}{\left| v_p \right|}\]
