13. Frequently asked questions¶
13.1. How do I ask a question, or send feedback?¶
Please allow sufficient time (5-7 business days) for MFiX developers and users to reply before posting unanswered questions again.
MFiX version.
Operating system.
*.mfx
,*.stl
,*.f
,particle_input.dat
etc.):Create a zip file from main menu> Submit bug report.
Run the solver in debug mode?
13.1.1. How do I build the custom solver in parallel?¶
parallel” check box. This will pass the -j
option to the make
command.
13.2. Pausing and restarting the solver¶
13.2.1. Play/Pause/Reinit¶
(save) button
and press the
(start) button.
13.2.2. Restart a simulation from current time¶
and press the
13.2.3. Restart a simulation from the beginning¶
First press the
(save) button, and press the
(start) button.
13.3. What system of units does MFiX use?¶
MFiX SI unit |
length, position |
meter \((m)\) |
mass |
kilogram \((kg)\) |
time |
second \((s)\) |
thermal temperature |
Kelvin \((K)\) |
energy† |
Joule \((J)\) |
amount of substance‡ |
kilomole \((kmol)\) |
force |
Newton (\(N = kg·m/s^2\)) |
Pascal (\(Pa = N/m^2\)) |
dynamic viscosity |
\(Pa·s\) |
kinematic viscosity |
\(m^2/s\) |
gas constant |
\(J/K·kmol\) |
enthalpy |
\(J\) |
specific heat |
\(J/kg·K\) |
thermal conductivity |
\(J/s·m·K\) |
amount per time per volume for Eulerian model reactions \(kmol/m^3.s\)
amount per time for Lagrangian model reactions \(kmol/s\)
13.4. What do I do if a run does not converge?¶
13.4.1. Initial non-convergence¶
Holding the time step constant (DT_FAC=1
) and ignoring the stalling of
iterations (DETECT_STALL=.FALSE.
) may help in overcoming initial nonconvergence.
When using constant gas density, better convergence may be achieved by increasing the number of gas pressure iterations. Go to Numerics>Linear solver tab and set the number of gas pressure iterations (“Iter.” column) to say 50 instead of 20.
reducing UR_FAC(2)
below the default value of 0.5.
Convergence is often difficult with higher order discretization methods. First order upwinding may be used to overcome initial transients and then the higher order method may be turned on. Also, higher-order methods such as van Leer and minmod give faster convergence than methods such as Superbee and ULTRA-QUICK.
13.4.2. Non-convergence due to bad cut-cell mesh¶
Figure 13.1 Removing small cut-cells¶
Errors related to singular matrix may be due to poor mesh quality as well. Warning messages such as:
WARNING leg_bicgs.f:269, Warning: Singular matrix detected when solving for: EPp
will likely lead to failure and are often caused by non water-tight geometry, inclomplete boundary condition specifications, STL files with collapsed edges. In these cases, it is recommended to first check the STL file and mesh quality (visualise the mesh and check the mesh statistics). Adjusting the meshing tolerances may help solve the issue.
13.5. Discrete Element Model (DEM)¶
13.5.1. How to provide initial particle positions in particle_input.dat file?¶
We can read the initial particle data from a text file, called particle_input.dat
To use the file rather than the automatic particle generation (i.e. from Initial conditions regions), go to the Solids > DEM pane, and leave the “Enable automatic particle generation” checkbox unchecked. Enter a positive number of particles to be read in the “Data file particle count”.
Below is an example of a particle_input.dat
file (the line number is shown on the left and it
not part of the data itself):
Lines 32-34: Data header
1 Version 2.0
3 Instructions:
19 Dimension: 3
20 Particles: 35361
25 Phase_ID: F 1
26 Diameter: T
27 Density: F 2500.0
28 Velocity: F 0.0 0.0 0.0
The particle_input.dat
file can be edited in any text editor, including the GUI editor, and be
Below is an example of a 2D particle_input.dat
(only 4 particles shown):
Below is an example of a 3D particle_input.dat
13.5.2. How to avoid particles going through solid walls in DEM simulations?¶
Figure 13.2 Left: Soft particles (kn=kn_w=100 N/m) going through the cyclone wall. Right: Harder particles (kn=kn_w=1000 N/m) bouncing off the wall.¶
Figure 13.3 Spring stiffness settings in the GUI¶
13.6. Superquadric Particle Model (SQP)¶
13.6.1. How to specify the particle shape?¶
Figure 13.4 Superquadric designer¶
Figure 13.5 Favorable exponent map¶
Examples:
a |
b |
c |
m |
n |
shape |
view |
0.003 |
0.003 |
0.003 |
2.0 |
2.0 |
sphere |
0.003 |
0.001 |
0.006 |
2.0 |
2.0 |
ellipsoid |
0.003 |
0.001 |
0.006 |
8.0 |
8.0 |
cuboid |
0.003 |
0.003 |
0.006 |
2.0 |
8.0 |
cylinder |
13.6.2. Recommended settings¶
13.7. Glued Sphere Particle Model (GSP)¶
13.7.1. How to specify the particle shape?¶
The Glued Sphere is an assembly of small spheres that approximates the shape of a non-spherical particle. It is obtained by discretizing the base shape into spheres through an algorithm controlled by a few parameters.
The real particle geometry can be defined either as a supequadric shape, using the same parameters as the SQP model \(a, b, c, m, n\), or by importing an STL file.
To define the Glued-sphere configuration for a given solids phase, click on the “Glued-sphere designer” button (Solids> Material pane). A new interactive widget will pop up, where the glued sphere parameters can be specified. By default, a cuboic with round edges is defined.
First, define the type of geometry input: Superquadric or STL file. For a superquadric geometry, enter the X, Y, Z semi-axes, and m, n exponents. If selecting an STL file, select “Choose STL file” to import the STL file. A preview of the base shape will be shown on the left viewport.
If needed, the base shape’s orientation can be modified using quaternions. Click “Apply quaternion” to apply the rotation or “Reset” to use the original orientation.
Next, the volume discretization must be specified. Enter the number of spheres in X, Y, and Z directions. Increasing the number os spheres will result in a better shape approximation, but long run-time. It is recommended to use the smallest number of spheres possible to avoid prohibitively long run time.
For complex or fine STL files, the mesh can be decimated (simplified) to speed up the glued sphere generation. Check the “Mesh decimation” box and provide a non-zero decimation ratio. Using a large decimation ratio may result in a loss of geometric details.
The glued sphere generation uses a bounding box to determine the extent of the geometry. The bounding box can be slightly extended to help the intersection algorithm by specifying a non-zero wall extension ratio.
Sometimes the algorithm will generate some very small spheres. These can create stability issues in the contact force calculation and/or unnecessarily small solids time step. To control how small spheres can be removed from the assembly, check the “remove small spheres” box. Then specify the small sphere ratio. When a sphere’s volume is less than this ratio times the largest sphere volume, this small sphere will be considered for removal. Next, specify the Maximum removal fraction. This will remove all small spheres identified in the previous step until their combined volume reaches the maximum removal fraction times the baseline particle volume.
Once all the parameters have been specified. press the “Generate GSP” button. The progress bar will update while the algorithm generates the glued sphere. Once generated, the glued sphere will be displayed in the viewport. The opacity of the base shape and the GSP can be adjusted for better visualization.
Figure 13.6 Glued-sphere designer¶
13.8. Meshing¶
13.8.1. How to verify/flip STL file facet normals?¶
Figure 13.7 Displaying STL normals, internal flow¶
Figure 13.8 Flipping STL normals to model an external flow¶
13.8.2. How to manually specify a grid partition for DMP runs?¶
To specify this decomposition, the following gridmap.dat
needs to be saved in the project directory:
0 10
1 10
0 10
1 10
2 10
3 70
0 10
1 10
Below is the entire gridmap.dat
file:
0 10
1 10
0 10
1 10
2 10
3 70
0 10
1 10
Figure 13.9 Default partition (uniform distribution)¶
Figure 13.10 Adjusted partition in vertical direction (specified with gridmap.dat)¶
13.9. Particle in Cell (PIC)¶
13.9.1. How To Choose a Good Statistical Weight for PIC Runs?¶
13.9.2. PIC statistical weight example¶
13.9.3. Meshing Basics for PIC Runs¶
13.9.4. Choosing Primary PIC Parameters¶
13.9.5. Choosing Secondary PIC parameters¶
13.9.6. Why can’t I define parcels per cell instead of particles per parcel?¶
13.9.7. What is a good number (or range) for the number of parcels per cells?¶
13.9.8. What solids model parameter values work best for the PIC model when running 2 densities that are roughly 10x different in magnitude?¶
