12.1.20. UDF control
12.1.20.1. CALL_USR
Table 12.100 Valid values
Call user-defined subroutines.
Do NOT call user-defined subroutines.
12.1.20.2. CALL_USR_SOURCE(EQUATION ID NUMBER)
Table 12.101 Valid values
Call user-defined source.
MFIX default: No additional source.
12.1.20.3. DES_USR_VAR_SIZE
12.1.20.4. USR_C(USER-DEFINED ID)
  • \(1 \le User-defined ID \le DIMENSION{\_}USR{\_}C\)
User defined constants.
12.1.20.5. USR_C_NAME(USER-DEFINED ID)
12.1.20.6. USR_CPG
Table 12.102 Valid values
Call user-defined function.
Use MFIX default calculation.
12.1.20.7. USR_CPS(PHASE)
Table 12.103 Valid values
12.1.20.8. USR_DIFG
Table 12.104 Valid values
12.1.20.9. USR_DIFS(PHASE)
Table 12.105 Valid values
12.1.20.10. USR_DT(USR)
  • \(1 \le USR \le 5\)
12.1.20.11. USR_EXT(USR)
12.1.20.12. USR_FGS(PHASE)
Table 12.106 Valid values
12.1.20.13. USR_FORMAT(USR)
UDF hook: Format for writing user-defined (ASCII) output file.
12.1.20.14. USR_FSS(PHASE)
  • \(1 \le Phase \le DIM{\_}LM\)
Table 12.107 Valid values
12.1.20.15. USR_GAMA(PHASE)
Table 12.108 Valid values
12.1.20.16. USR_I_E(USR)
12.1.20.17. USR_I_W(USR)
12.1.20.18. USR_J_N(USR)
12.1.20.19. USR_J_S(USR)
12.1.20.20. USR_K_B(USR)
12.1.20.21. USR_K_T(USR)
12.1.20.22. USR_KG
Table 12.109 Valid values
12.1.20.23. USR_KS(PHASE)
Table 12.110 Valid values
12.1.20.24. USR_MUG
Table 12.111 Valid values
12.1.20.25. USR_MUS(PHASE)
Table 12.112 Valid values
12.1.20.26. USR_ROG
Table 12.113 Valid values
12.1.20.27. USR_ROS(PHASE)
Table 12.114 Valid values
12.1.20.28. USR_TYPE(USR)
12.1.20.29. USR_VAR(USR)
UDF hook: Variable to be written in the user-defined output files.
12.1.20.30. USR_X_E(USR)
12.1.20.31. USR_X_W(USR)
12.1.20.32. USR_Y_N(USR)
12.1.20.33. USR_Y_S(USR)
12.1.20.34. USR_Z_B(USR)
12.1.20.35. USR_Z_T(USR)
