12.1.11. Output control¶
12.1.11.1. BDIST_IO¶
12.1.11.2. BREAKDOWN_SOLID_INVENTORY_BY_PHASE¶
Required
12.1.11.3. BSTART_WITH_ONE_RES¶
12.1.11.4. DEBUG_DES¶
12.1.11.5. DES_OUTPUT_TYPE¶
ParaView formatted files (.vtp) |
Tecplot formatted files (.dat) |
12.1.11.6. DES_REPORT_MASS_INTERP¶
12.1.11.7. FOCUS_PARTICLE¶
12.1.11.8. FRAME(VTK)¶
\(1 \le VTK \le 100\)
12.1.11.9. FULL_LOG¶
- Display the residuals on the screen and provide
12.1.11.10. GROUP_RESID¶
12.1.11.11. MONITOR_DES_RRATE(MONITOR, RATE)¶
\(1 \le Monitor \le DIMENSION{\_}MONITOR\)
\(1 \le RATE \le NRRMAX\)
Write particle/parcel reaction rates in region. Particle/parcel data is converted to cell data.
12.1.11.12. MONITOR_DES_USR_VAR(MONITOR, USR_VAR)¶
\(1 \le USR_VAR \le 100\)
Write des_usr_var in region.
12.1.11.13. MONITOR_DT(MONITOR)¶
12.1.11.14. MONITOR_E_TURB_G(MONITOR)¶
12.1.11.15. MONITOR_EP_G(MONITOR)¶
12.1.11.16. MONITOR_EP_S(MONITOR, PHASE)¶
12.1.11.17. MONITOR_FLUID_RRATE(MONITOR, RATE)¶
Write fluid reaction rates in region. This keyword replaces MONITOR_RRate and does not require users to write code to save data in ReactionRates(:,:) array.
12.1.11.18. MONITOR_K_TURB_G(MONITOR)¶
12.1.11.19. MONITOR_MW_MIX_G(MONITOR)¶
12.1.11.20. MONITOR_NAME(MONITOR)¶
12.1.11.21. MONITOR_P_G(MONITOR)¶
12.1.11.22. MONITOR_P_S(MONITOR, PHASE)¶
12.1.11.23. MONITOR_P_STAR(MONITOR)¶
12.1.11.24. MONITOR_PART_PHASE(MONITOR, PHASE)¶
12.1.11.25. MONITOR_PART_RESIDENCE_TIME(MONITOR)¶
12.1.11.26. MONITOR_PART_RRATE(MONITOR, RATE)¶
\(1 \le rate \le 100\)
12.1.11.27. MONITOR_PCOUNT(MONITOR)¶
12.1.11.28. MONITOR_PMASS(MONITOR)¶
12.1.11.29. MONITOR_PVOL(MONITOR)¶
12.1.11.30. MONITOR_RADIUS(MONITOR)¶
12.1.11.31. MONITOR_RO_G(MONITOR)¶
12.1.11.32. MONITOR_RO_P(MONITOR)¶
12.1.11.33. MONITOR_RO_S(MONITOR, PHASE)¶
12.1.11.34. MONITOR_ROP_S(MONITOR, PHASE)¶
12.1.11.35. MONITOR_ROT_X(MONITOR)¶
12.1.11.36. MONITOR_ROT_Y(MONITOR)¶
12.1.11.37. MONITOR_ROT_Z(MONITOR)¶
12.1.11.38. MONITOR_RRATE(MONITOR, RATE)¶
12.1.11.39. MONITOR_SCALAR(MONITOR, SCALAR EQ.)¶
\(1 \le Scalar Eq. \le 100\)
Write scalar in region.
12.1.11.40. MONITOR_T_G(MONITOR)¶
12.1.11.41. MONITOR_T_P(MONITOR)¶
12.1.11.42. MONITOR_T_S(MONITOR, PHASE)¶
12.1.11.43. MONITOR_TAVG_DT(MONITOR)¶
12.1.11.44. MONITOR_TAVG_RESET_DT(MONITOR)¶
12.1.11.45. MONITOR_TAVG_SS_SPAN(MONITOR)¶
12.1.11.46. MONITOR_TAVG_SS_TOL(MONITOR)¶
12.1.11.47. MONITOR_TAVG_START(MONITOR)¶
12.1.11.48. MONITOR_THETA_M(MONITOR, PHASE)¶
12.1.11.49. MONITOR_TYPE(MONITOR)¶
Data monitor type.
Point value |
Sum over region |
Minimum over region |
Maximum over region |
Arithmetic average over region |
Standard deviation over region |
Area-weighted average over surface |
Flow rate across surface |
Mass flow rate across surface |
Mass-weighted average over surface |
Volumetric flow rate over surface |
Volume integral |
Volume-weighted average |
Mass-weighted volume integral |
Mass-weighted volume average |
Sum over region |
Mass-weighted average over region |
Volume-weighted average over region |
Mass-weighted flow rate across surface |
Volume-weighted flow rate across surface |
12.1.11.50. MONITOR_U_G(MONITOR)¶
12.1.11.51. MONITOR_U_S(MONITOR, PHASE)¶
12.1.11.52. MONITOR_V_G(MONITOR)¶
12.1.11.53. MONITOR_V_S(MONITOR, PHASE)¶
12.1.11.54. MONITOR_VEL_X(MONITOR)¶
12.1.11.55. MONITOR_VEL_Y(MONITOR)¶
12.1.11.56. MONITOR_VEL_Z(MONITOR)¶
12.1.11.57. MONITOR_W_G(MONITOR)¶
12.1.11.58. MONITOR_W_S(MONITOR, PHASE)¶
12.1.11.59. MONITOR_X_E(MONITOR)¶
12.1.11.60. MONITOR_X_G(MONITOR, SPECIES)¶
\(1 \le Species \le 100\)
12.1.11.61. MONITOR_X_P(MONITOR, SPECIES)¶
12.1.11.62. MONITOR_X_S(MONITOR, PHASE, SPECIES)¶
12.1.11.63. MONITOR_X_W(MONITOR)¶
12.1.11.64. MONITOR_Y_G(MONITOR, SPECIES)¶
12.1.11.65. MONITOR_Y_N(MONITOR)¶
12.1.11.66. MONITOR_Y_S(MONITOR)¶
12.1.11.67. MONITOR_Z_B(MONITOR)¶
12.1.11.68. MONITOR_Z_T(MONITOR)¶
12.1.11.69. NLOG¶
12.1.11.70. NRR¶
12.1.11.71. OUT_DT¶
- Time interval at which standard output (.OUT) file is updated.
12.1.11.72. PART_IN_DENSITY_EXCLUDE¶
Density filter selection mode applied to particles read from particle input file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.11.73. PART_IN_DENSITY_MAX¶
Density maximum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless corresponding PART_IN_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.74. PART_IN_DENSITY_MIN¶
Density minimum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless corresponding PART_IN_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.75. PART_IN_DIAMETER_EXCLUDE¶
Diameter filter selection mode applied to particles read from particle input file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.11.76. PART_IN_DIAMETER_MAX¶
Diameter maximum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless corresponding PART_IN_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.77. PART_IN_DIAMETER_MIN¶
Diameter minimum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless corresponding PART_IN_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.78. PART_IN_PHASE(PHASE)¶
Solids phase filter applied to particles read from particle input file. Change to .FALSE. to exclude particles belonging to this phase.
12.1.11.79. PART_IN_TEMP_EXCLUDE¶
Temperature filter selection mode applied to particles read from particle input file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.11.80. PART_IN_TEMP_MAX¶
Temperature maximum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless corresponding PART_IN_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.81. PART_IN_TEMP_MIN¶
Temperature minimum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless corresponding PART_IN_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.82. PART_IN_U_EXCLUDE¶
X-velocity filter selection mode applied to particles read from particle input file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.11.83. PART_IN_U_MAX¶
X-velocity maximum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless corresponding PART_IN_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.84. PART_IN_U_MIN¶
X-velocity minimum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless corresponding PART_IN_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.85. PART_IN_USR_VAR_EXCLUDE(INDEX)¶
\(1 \le Index \le 100\)
User-defined variable filter selection mode applied to particles read from particle input file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.11.86. PART_IN_USR_VAR_MAX(INDEX)¶
User-defined variable maximum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless corresponding PART_IN_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.87. PART_IN_USR_VAR_MIN(INDEX)¶
User-defined variable minimum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless corresponding PART_IN_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.88. PART_IN_V_EXCLUDE¶
Y-velocity filter selection mode applied to particles read from particle input file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.11.89. PART_IN_V_MAX¶
Y-velocity maximum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless corresponding PART_IN_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.90. PART_IN_V_MIN¶
Y-velocity minimum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless corresponding PART_IN_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.91. PART_IN_W_EXCLUDE¶
Z-velocity filter selection mode applied to particles read from particle input file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.11.92. PART_IN_W_MAX¶
Z-velocity maximum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless corresponding PART_IN_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.93. PART_IN_W_MIN¶
Z-velocity minimum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless corresponding PART_IN_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.94. PART_IN_X_EXCLUDE¶
X-coordinate filter selection mode applied to particles read from particle input file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.11.95. PART_IN_X_MAX¶
X-coordinate maximum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless corresponding PART_IN_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.96. PART_IN_X_MIN¶
X-coordinate minimum value of the filter applied to particles read from particle_input file. By default, particles with data between min and max value are written out, unless corresponding PART_IN_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.97. PART_IN_X_S_EXCLUDE(INDEX)¶
Species filter selection mode applied to particles read from particle input file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.11.98. PART_IN_X_S_MAX(INDEX)¶
Species maximum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless corresponding PART_IN_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.99. PART_IN_X_S_MIN(INDEX)¶
Species minimum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless corresponding PART_IN_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.100. PART_IN_Y_EXCLUDE¶
Y-coordinate filter selection mode applied to particles read from particle input file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.11.101. PART_IN_Y_MAX¶
Y-coordinate maximum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless corresponding PART_IN_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.102. PART_IN_Y_MIN¶
Y-coordinate minimum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless corresponding PART_IN_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.103. PART_IN_Z_EXCLUDE¶
Z-coordinate filter selection mode applied to particles read from particle input file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.11.104. PART_IN_Z_MAX¶
Z-coordinate maximum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless corresponding PART_IN_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.105. PART_IN_Z_MIN¶
Z-coordinate minimum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless corresponding PART_IN_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.106. PART_OUT_DENSITY_EXCLUDE¶
Density filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select only particles with data outside the [min;max] range.
12.1.11.107. PART_OUT_DENSITY_MAX¶
Density maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.108. PART_OUT_DENSITY_MIN¶
Density minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.109. PART_OUT_DIAMETER_EXCLUDE¶
Diameter filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select only particles with data outside the [min;max] range.
12.1.11.110. PART_OUT_DIAMETER_MAX¶
Diameter maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.111. PART_OUT_DIAMETER_MIN¶
Diameter minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.112. PART_OUT_PHASE(PHASE)¶
Solids phase filter selection mode applied to particles written in particle output file. Change to .FALSE. to exclude particles belonging to this phase.
12.1.11.113. PART_OUT_TEMP_EXCLUDE¶
Temperature filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.11.114. PART_OUT_TEMP_MAX¶
Temperature maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.115. PART_OUT_TEMP_MIN¶
Temperature minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.116. PART_OUT_U_EXCLUDE¶
X-velocity filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select only particles with data outside the [min;max] range.
12.1.11.117. PART_OUT_U_MAX¶
X-velocity maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.118. PART_OUT_U_MIN¶
X-velocity minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.119. PART_OUT_USR_VAR_EXCLUDE(INDEX)¶
User-defined variable filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.11.120. PART_OUT_USR_VAR_MAX(INDEX)¶
User-defined variable maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.121. PART_OUT_USR_VAR_MIN(INDEX)¶
User-defined variable minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.122. PART_OUT_V_EXCLUDE¶
Y-velocity filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select only particles with data outside the [min;max] range.
12.1.11.123. PART_OUT_V_MAX¶
Y-velocity maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.124. PART_OUT_V_MIN¶
Y-velocity minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.125. PART_OUT_W_EXCLUDE¶
Z-velocity filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.11.126. PART_OUT_W_MAX¶
Z-velocity maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.127. PART_OUT_W_MIN¶
Z-velocity minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.128. PART_OUT_X_EXCLUDE¶
X-coordinate filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select only particles with data is outside the [min;max] range.
12.1.11.129. PART_OUT_X_MAX¶
X-coordinate maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.130. PART_OUT_X_MIN¶
X-coordinate minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.131. PART_OUT_X_S_EXCLUDE(INDEX)¶
Species filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.11.132. PART_OUT_X_S_MAX(INDEX)¶
Species maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.133. PART_OUT_X_S_MIN(INDEX)¶
Species minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.134. PART_OUT_Y_EXCLUDE¶
Y-coordinate filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select only particles with data outside the [min;max] range.
12.1.11.135. PART_OUT_Y_MAX¶
Y-coordinate maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.136. PART_OUT_Y_MIN¶
Y-coordinate minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.137. PART_OUT_Z_EXCLUDE¶
Z-coordinate filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select only particles with data outside the [min;max] range.
12.1.11.138. PART_OUT_Z_MAX¶
Z-coordinate maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.139. PART_OUT_Z_MIN¶
Z-coordinate minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.140. PART_OUT_ZERO_VEL¶
Option to reset the velocity to zero in the particle output file. Default value is .False. (do not reset the velocity to zero).
12.1.11.141. PHIP_OUT_JJ¶
12.1.11.142. PRINT_DES_DATA¶
Allows writing of discrete particle data to output files. Relevant to both granular and coupled simulations.
12.1.11.143. REPORT_MASS_BALANCE_DT¶
12.1.11.144. REPORT_NEG_DENSITY¶
Do not log negative density errors. |
Log negative density errors. |
12.1.11.145. REPORT_NEG_SPECIFICHEAT¶
Do not log zero or negative specific heat errors. |
Log zero or negative specific heat errors. |
12.1.11.146. REPORT_SOLID_INVENTORY¶
Required
12.1.11.147. REPORT_SOLID_INVENTORY_DT¶
Required
12.1.11.148. RES_BACKUP_DT¶
12.1.11.149. RES_BACKUPS¶
12.1.11.150. RES_DT¶
Required
12.1.11.151. RESID_STRING(RESIDUAL INDEX)¶
\(1 \le Residual Index \le 8\)
Gas pressure |
Solids phase M pressure |
Gas density |
Solids phase M density |
Gas phase U-velocity |
Gas phase V-velocity |
Gas phase W-velocity |
Solids phase M U-velocity |
Solids phase M V-velocity |
Solids phase M W-velocity |
Gas temperature |
Solids phase M temperature |
Solids phase M granular temperature |
Gas phase species NN mass fraction |
Solids phase M species NN mass fraction |
K-Epsilon model residuals |
12.1.11.152. SPX_DT(SP VALUE)¶
\(1 \le SP Value \le 11\)
SP1: void fraction (EP_G)
SP2: Gas pressure (P_G) and Solids pressure (P_star)
SP3: Gas velocity (U_G, V_G, W_G)
SP4: Solids velocity (U_S, V_S, W_S)
SP5: Solids bulk density (ROP_s)
SP6: Gas and solids temperature (T_G, T_S)
SP7: Gas and solids mass fractions (X_G, X_S)
SP8: Granular temperature (THETA_M)
SP9: User defined scalars (SCALAR)
SPA: Reaction Rates (ReactionRates)
SPB: Turbulence quantities (K_TURB_G, E_TURB_G)
12.1.11.153. TIME_DEPENDENT_FILENAME¶
The VTK file overwrites the previous file (recommended for steady-state computation). |
A sequential integer is appended to the VTK filenames as they are written to create a series of files (recommended for transient computation). |
12.1.11.154. TSS_HDR¶
- Write header every TSS_HDR iterations on screen.
12.1.11.155. VTK_BC_ID(VTK)¶
12.1.11.156. VTK_C_PG(VTK)¶
12.1.11.157. VTK_C_PS(VTK, PHASE)¶
12.1.11.158. VTK_CUTCELL_ONLY(VTK)¶
12.1.11.159. VTK_DATA(VTK)¶
Cell data (VTU file). |
Particle data (VTP file). |
Geometry data (STL file). |
Force chain data (VTP file). |
Glued (non-spherical) particle data (VTP file). |
12.1.11.160. VTK_DBG_FILE(VTK)¶
When VTK_DBG_FILE is .TRUE., the VTK region file is only written when the subroutine WRITE_DBG_VTU_AND_VTP_FILES is called, typically in a UDF.
12.1.11.161. VTK_DEBUG(VTK, IDX)¶
\(1 \le IDX \le 15\)
12.1.11.162. VTK_DES_RRATE(VTK, RATE)¶
\(1 \le rate \le nRRmax\)
Write Lagrangian (DEM, CGDEM, PIC) reaction rates in region. Particle/parcel data is accumulated in fluid cells.
12.1.11.163. VTK_DT(VTK)¶
12.1.11.164. VTK_DWALL(VTK)¶
12.1.11.165. VTK_E_TURB_G(VTK)¶
12.1.11.166. VTK_EP_G(VTK)¶
12.1.11.167. VTK_EP_S(VTK, PHASE)¶
12.1.11.168. VTK_FACET_COUNT_DES(VTK)¶
12.1.11.169. VTK_FCMAX_ONLY(VTK)¶
12.1.11.170. VTK_FILEBASE(VTK)¶
12.1.11.171. VTK_FLUID_RRATE(VTK, RATE)¶
12.1.11.172. VTK_GEO(VTK, GEO)¶
\(1 \le GEO \le VTK{\_}GEO{\_}MAX\)
12.1.11.173. VTK_GSP_OUTPUT_TYPE(VTK)¶
Type of GSP output shape in VTK files.
Use actual glued particle shape (show all component spheres). |
Use bounding sphere to represent entire GSP. |
12.1.11.174. VTK_IJK(VTK)¶
12.1.11.175. VTK_K_TURB_G(VTK)¶
12.1.11.176. VTK_LAMBDA_2(VTK)¶
Write lambda_2 in region.
12.1.11.177. VTK_MU_G(VTK)¶
12.1.11.178. VTK_MW_MIX_G(VTK)¶
12.1.11.179. VTK_NB_FACET_DES(VTK)¶
12.1.11.180. VTK_NORMAL(VTK)¶
12.1.11.181. VTK_NXS(VTK)¶
12.1.11.182. VTK_NYS(VTK)¶
12.1.11.183. VTK_NZS(VTK)¶
12.1.11.184. VTK_P_G(VTK)¶
12.1.11.185. VTK_P_S(VTK, PHASE)¶
12.1.11.186. VTK_P_STAR(VTK)¶
12.1.11.187. VTK_PART_ANGULAR_VEL(VTK)¶
12.1.11.188. VTK_PART_C_PS(VTK)¶
12.1.11.189. VTK_PART_CGP_STAT_WT(VTK)¶
12.1.11.190. VTK_PART_COHESION(VTK)¶
12.1.11.191. VTK_PART_COL_FORCE(VTK)¶
12.1.11.192. VTK_PART_COORDINATION(VTK)¶
Write particle coordination number in region.
12.1.11.193. VTK_PART_DENSITY(VTK)¶
12.1.11.194. VTK_PART_DIAMETER(VTK)¶
12.1.11.195. VTK_PART_DRAG_COEFF(VTK)¶
12.1.11.196. VTK_PART_GLUEBOUNDING(VTK)¶
12.1.11.197. VTK_PART_GLUEDIAMETER(VTK)¶
12.1.11.198. VTK_PART_GLUEID(VTK)¶
12.1.11.199. VTK_PART_GLUEMASS(VTK)¶
12.1.11.200. VTK_PART_GLUEQUAT(VTK)¶
12.1.11.201. VTK_PART_GLUEVOLUME(VTK)¶
12.1.11.202. VTK_PART_ID(VTK)¶
Write particle ID in region.
12.1.11.203. VTK_PART_MASS(VTK)¶
12.1.11.204. VTK_PART_ORIENTATION(VTK)¶
12.1.11.205. VTK_PART_OVERLAP_STATS(VTK)¶
Write particle overlap statistics (min, max, mean) in region.
12.1.11.206. VTK_PART_PHASE(VTK, PHASE)¶
12.1.11.207. VTK_PART_PHASE_ID(VTK)¶
12.1.11.208. VTK_PART_PHYSICAL_DIAMETER(VTK)¶
12.1.11.209. VTK_PART_RANK(VTK)¶
12.1.11.210. VTK_PART_RESIDENCE_TIME(VTK)¶
12.1.11.211. VTK_PART_RRATE(VTK, RATE)¶
12.1.11.212. VTK_PART_TEMP(VTK)¶
12.1.11.213. VTK_PART_USR_VAR(VTK, USR_VAR)¶
\(1 \le USR_VAR \le VTK{\_}PART{\_}USRmax\)
12.1.11.214. VTK_PART_VEL(VTK)¶
12.1.11.215. VTK_PART_VOLUME(VTK)¶
12.1.11.216. VTK_PART_X_S(VTK, DES_SPECIES)¶
\(1 \le Des_species \le 100\)
12.1.11.217. VTK_PARTITION(VTK)¶
12.1.11.218. VTK_RO_G(VTK)¶
12.1.11.219. VTK_RO_S(VTK, PHASE)¶
12.1.11.220. VTK_ROP_S(VTK, PHASE)¶
12.1.11.221. VTK_RRATE(VTK, RATE)¶
12.1.11.222. VTK_RRATE_LABEL(VTK, RATE)¶
12.1.11.223. VTK_SCALAR(VTK, SCALAR)¶
\(1 \le Scalar \le DIM{\_}scalar\)
12.1.11.224. VTK_SCALAR_CC(VTK)¶
12.1.11.225. VTK_SELECT_MODE(VTK)¶
Select particles with centers inside the VTK region. |
Select particles that are entirely inside the VTK region. |
Select particles that are inside or intersect the edges of the VTK region. |
12.1.11.226. VTK_SLICE_TOL(VTK)¶
12.1.11.227. VTK_T_END(VTK)¶
12.1.11.228. VTK_T_G(VTK)¶
12.1.11.229. VTK_T_S(VTK, PHASE)¶
12.1.11.230. VTK_T_START(VTK)¶
12.1.11.231. VTK_THETA_M(VTK, PHASE)¶
12.1.11.232. VTK_U_G(VTK)¶
12.1.11.233. VTK_U_S(VTK, PHASE)¶
12.1.11.234. VTK_V_G(VTK)¶
12.1.11.235. VTK_V_S(VTK, PHASE)¶
12.1.11.236. VTK_VAR(IDX)¶
\(1 \le IDX \le 20\)
Void fraction (EP_g) |
Gas pressure, solids pressure (P_g, P_star) |
Gas velocity (U_g, V_g, W_g) |
Solids velocity (U_s, V_s, W_s) |
Solids density (ROP_s) |
Gas and solids temperature (T_g, T_s) |
Gas and solids mass fractions (X_g, X_s) |
Granular temperature (Theta_m) |
Scalar |
Reaction rates |
K and Epsilon |
Vorticity magnitude and lambda_2 |
Grid Partition |
Boundary Condition ID |
Distance to wall |
DEM facet count |
DEM Neighboring facets |
Cell IJK index |
Cut face normal vector |
12.1.11.237. VTK_VEL_G(VTK)¶
12.1.11.238. VTK_VEL_S(VTK, PHASE)¶
12.1.11.239. VTK_VORTICITY(VTK)¶
12.1.11.240. VTK_W_G(VTK)¶
12.1.11.241. VTK_W_S(VTK, PHASE)¶
12.1.11.242. VTK_X_E(VTK)¶
12.1.11.243. VTK_X_G(VTK, GAS SPECIES)¶
\(1 \le Gas Species \le DIM{\_}N{\_}g\)
12.1.11.244. VTK_X_S(VTK, PHASE, SOLIDS SPECIES)¶
\(1 \le Solids Species \le DIM{\_}N{\_}s\)
12.1.11.245. VTK_X_W(VTK)¶
12.1.11.246. VTK_Y_G(VTK, GAS SPECIES)¶
12.1.11.247. VTK_Y_N(VTK)¶
12.1.11.248. VTK_Y_S(VTK)¶
12.1.11.249. VTK_Z_B(VTK)¶
12.1.11.250. VTK_Z_T(VTK)¶
12.1.11.251. VTP_DIR¶
12.1.11.252. VTU_DIR¶
Directory where VTK files are stored. By default, VTK files are written in the run directory.
12.1.11.253. WRITE_PART_OUT¶
Option to write a particle output file at the end of a simulation. After the simulation, the file can be renamed as particle_input.csv and used as initial condition for another simulation. For example, a first granular DEM simulation can be run fairly quickly to settle a bed of particles and the data saved in this file can be used to start a new coupled simulation. Default value is .False. (do not write the file).
12.1.11.254. WRITE_VTK_FILES¶
Do not write VTK files. If there are cut cells, they will not be displayed from the usual .res file |
Valid only if Cartesian_grid = .TRUE. |
